Sponsored by: Kumho
TIRE SIZE EQUALS?????
Old Jul 10, 2002 | 05:48 PM
bigFAWKINranger
Guest
Posts: n/a
Old Jul 11, 2002 | 04:56 PM
ford311's Avatar
ford311
HI i have a 92 f150 xlt and i wanna get sme new tires and i was just wondering what p245/70 r 15 equals! casue in all the magizens and everything i keep seeing 35 this and that! an di dont know how to measure to measure so if someone coul dhelp me out !!thanks!
Old Jul 11, 2002 | 05:30 PM
AlM's Avatar
AlM
yo 311,
Here is a GY site with specs on that size:
http://www.goodyeartires.com/catalog/products/WRLRFASize.html
I picked that tire for relative specs only.
be well!
Old Jul 11, 2002 | 05:49 PM
RBrendel's Avatar
RBrendel
they have interactive calculators on tyres1.com thats what i use
Old Jul 12, 2002 | 11:16 AM
StrangeRanger's Avatar
StrangeRanger
245/70-15 is 28.5" diameter
Old Jul 12, 2002 | 01:00 PM
slimersoup's Avatar
slimersoup
245 is the section width in millimeters. It is 245/25.4 = 9.64 inches wide. 245 times 70 percent is your sidewall height. The sidewall is 245 * .7 = 171.5 millimeters tall, or 171.5/25.4 = 6.75 inches tall. The height of the tire equals the rim height plus two sidewall heights, or 15 + 6.75 + 6.75 = 28.5 inches. So it is a 28.5x9.6R15 in flotation tire size notation. Of course the actual size of the tire varies from this a little, normally shorter by a little bit. The smallest normal size that tires are rated in flotation tire size is 30x9.50, which fits just fine on an F150 by the way, just a bit taller than stock. Unless you like the look of a little wider tire, I would get some 235/75R15's (28.9x9.25R15) or 30x9.5R15's as they should be cheaper, and alot bigger selection of tires are available. 245/70R15 is kindof an odd size, mainly only used on F150's and Jeep Grand Cherokee's so that they looked a little more sporty from the factory.
Old Jul 12, 2002 | 01:58 PM
ford311's Avatar
ford311
hey slimer thanks so much!!!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
