Modular V10 (6.8l)
2006 SD V-10 Fuel Filter problem
Old Nov 25, 2007 | 06:42 PM
fdnylax's Avatar
fdnylax
Greetings Folks,
I went to change the fuel filter on my 06 f250 CC V-10 today and was unable to get my release tool to work. I also noticed that the fuel line fittings are different than my 01 f150. These fittings appear to have a blue plastic ring inside the end where you insert the release tool.
I have changed this type of filter before, but not on my 06. Does anyone know if Fomoco has changed the type of fittings used on the fuel filters? Thanks.
Old Nov 25, 2007 | 07:46 PM
llcustom's Avatar
llcustom
I do not think they did, BUT I do not know for sure, so I guess my comments do not really help any But i am here for ya! haha
Old Nov 26, 2007 | 02:37 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Did you try pushing the fuel line towards the filter, and while holding it like that, insert the tool?
I don't know why, but this rings a bell...
GUYS?!??!?!?!?
Old Nov 26, 2007 | 08:19 PM
fdnylax's Avatar
fdnylax
GUYS?!??!?!?!?
Thats why you are the moderator. I remember it later, from the last time I changed it on my training truck ( F150 ) Pushed the line towards the filter and with a little wiggling it popped. Thanks, Krewat
PS The connectors are different from previous years, they appear much larger although they still use a 3/8 tool. There is a blue plastic ring that is partially visible from the outside but they still unlock the same way.
Old Nov 26, 2007 | 10:22 PM
krewat's Avatar
krewat
Knowledge has very little to do with being a moderator - being a gabby SOB, that's something else
Old Nov 27, 2007 | 04:52 AM
V10man's Avatar
V10man
On my 05 you did not need the tool. That's what the blue clips are for.
Old Nov 27, 2007 | 12:16 PM
dockrocker's Avatar
dockrocker
Details, please - I need to change my '05 and I couldn't for the life of me figure out how to do it with (or without) the tool. Laying on the 35 degree concrete garage floor did not help my thinking
Old Nov 27, 2007 | 09:32 PM
super 6.8's Avatar
super 6.8
I have wondered that too. It looks like you can just push the blue clips and pull it off. I haven't tried, but with 11k miles I am getting close.
Old Nov 28, 2007 | 01:42 AM
V10man's Avatar
V10man
I only changed it a cpl times and my tool from my 99 didn't work. Somehow I used the blue clips. Don't have the truck anymore so I can't go look to refresh my memory.
Old Nov 28, 2007 | 08:54 AM
fdnylax's Avatar
fdnylax
I was able to get it done using a 3/8 removal tool, it just looks alot different from the older style. There is no metal flip collar around it, and the diameter of the connector piece seems to be much larger although it still uses the same size tool. I am not sure what the blue clips do, they seem to be part of the clip that holds the filter. I just made sure to push the fuel line towards the filter as far as possible, then inserted the tool and the line popped right off.
Old Nov 28, 2007 | 10:18 AM
krewat's Avatar
krewat
There was supposed to be a clip that would make sure the fuel line would never come off - I wonder if you forced your way through that second clip?
Some 2005 SD's were recalled at one point to either upgrade or install a new clip on the fuel filter.
Old Nov 28, 2007 | 10:55 AM
dockrocker's Avatar
dockrocker
Ah, now that you mention that, the delivery of my truck was delayed just for that clip installation.
xcnick38
Nov 4, 2007 10:55 PM
mhs53
Oct 9, 2007 06:00 PM
fuddy
Aug 26, 2007 02:08 PM
chevyhater74
1983 - 2012 Ranger & B-Series
Jun 26, 2007 01:10 PM
msbehvin69
Modular V10 (6.8l)
Mar 16, 2007 11:05 AM
