broken shifter
Old Nov 26, 2007 | 01:51 AM
mike_rockwell's Avatar
mike_rockwell
broken shifter
i have a 1988 f150 4x4 with a 302 and a 5 speed tranny and the shifter is loose like you all know how the shifter on a stick transmission is supposed to move straight left to right when its in nuetral well when mines in nuetral it goes in sort of a j pattern towards 1rst gear but its hard to get in 1rst gear ive talked to alot of people and they all said that body style ford had problems with thier shifter pins breaking aloot. but i pulled the shifter boot up out of the way and when i was looking at the shift ball and there was some sort of ring that went around the shifter that looked like it was broke too. so i guess my question is what could cause the play in the shifter.
Old Nov 26, 2007 | 09:10 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from '09 F150. Welcome and thanks for joining us at FTE!
Old Feb 23, 2008 | 02:44 PM
doolbxo's Avatar
doolbxo
yes, I have the same problem. I want to know also pleeeeaaaassseeeee! Thanks.
Old Feb 23, 2008 | 03:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Wear.
Your truck is 20 years old...how many times has the shift lever been moved.. ..20,000 times?
You have (I assume) the TK (Mazda) 5 Speed.
The shift lever is in two pieces. The lower shift lever, ball and socket and bearing/washers are worn.
1988 TK 5 Speed / Parts List 70.8AC
E8TZ-7228-C.. Ball & Socket
E8TZ-7210-C .. Shift Lever-Lower Half
E8TZ-7228-C .. Bearing/Washers
Old Feb 23, 2008 | 04:45 PM
TheRoadVirus's Avatar
TheRoadVirus
I just removed my old shifter and replaced it with a hurst, wanna buy it for cheap?
Was working fine and dandy when removed. It's even got a different head piece that's nicer than the stock one.
Ed; check out my 'Hurst Shifter Install' thread and you'll see the old one.
Old Feb 23, 2008 | 08:28 PM
TheRoadVirus
Sooooo? Ya want it?
Old Feb 25, 2008 | 01:16 PM
doolbxo's Avatar
doolbxo
Alright, here is my fix. I took off the boot, and unscrewed the top flange. Then removed the cover underneath, and the spring. At this point you can see the pin. Mine was broken, causing the swivel. You can also (carefully) pull the whole shifter out now. On the 88 model (and maybe the 89?), that pin only seats halfway through the shifter (thus the common breakage). I removed the broken part that was left, careful to not let it drop into the transmission case. Then, cut a new roll pin to size with a grinder and put it back together. Thats that.
Old Jan 15, 2010 | 05:52 PM
mike_rockwell
broken shifter
mine was the broken pin as well but after i replaced the pins it started grinding when shifting from first to second. so i drove it till it till my neighbor blew the engine last fall and junked it and bought a 92 f 150
Patrick Sanders
Jun 13, 2017 07:19 AM
Ronnief150man
Dec 8, 2016 10:19 PM
kimara3002
Oct 12, 2016 06:38 PM
Scfsouth
18
Mar 20, 2016 10:06 PM
torquemeister
Aug 27, 2014 09:16 AM
