calif emissions nightmare
Old Jan 15, 2010 | 04:11 PM
ryderontherun's Avatar
ryderontherun
87 F250 w/calif imissions most vacuum lines are off broken or hooked up to the wrong thing. but it still runs barly. about 4-5 miles to the gallon I think its a 351 not a 460 need vacuum hose diagram or can I get rid of calif emiss im in washington now and they dont require it. the belt is off the pumps anyway all three of them advise please. or color coded diagram.
Old Jan 15, 2010 | 05:17 PM
rla2005's Avatar
rla2005
Start with a Haynes and/or Chilton's manual. The VEC1 labels available from the Motorcraft Service website only show basic vacuum routing as required for emissions. You might also search on the 'net for an EVTM manual for your year/model truck. EVTM = Electrical and Vacuum Troubleshooting Manual. Ford has produced these for years as service manuals for their service techs.
Old Jan 15, 2010 | 06:14 PM
Big-old-460's Avatar
Big-old-460
hey bro welcome to the site.. as for your problem chiltons manual will do you might be able to find a .PDF version on line .. also you might run in to a problem removein stuff Some EECs are built to read sensors on your truck ,etc, and if it has cali emms, before takeing the junk off might make your eng not even run at all or horrible...
i cant help you bc i dont know whats what , i myself live in cali and deal with the emms every two yrs... i went to the smog check center 6 times in one day before AH HA... good luck hope someone else can help you .. just make sure it doesnt mess up your eng/EEC
l8ter
jayson
78 & 87 Super Cab
Jan 15, 2013 09:04 PM
rodnok
Mar 8, 2011 01:19 PM
BobbyFord
21
May 2, 2008 06:08 PM
You Betcha
Jul 8, 2004 10:03 PM
chuck_1
Aug 16, 1999 04:07 PM
