Weird noise
Old Sep 25, 2013 | 11:12 PM
lemasters f100's Avatar
lemasters f100
Weird noise
Ok my 1978 f250 with a 400 in it has started making a weird stuffer or poping noise when driving 25mph+ is this just bad gas? Maybe clogged jet? Bad filters?
Old Sep 25, 2013 | 11:13 PM
lemasters f100
It has the stock motorcraft carburetor
Old Sep 26, 2013 | 08:21 AM
rogue40's Avatar
rogue40
Loose spark plug wire.
Old Sep 26, 2013 | 10:55 AM
lemasters f100
I checked that. Maybe a timing issue?
Old Sep 26, 2013 | 11:53 PM
Boodrow379's Avatar
Boodrow379
Give us a little more information, standard or automatic, what rpm does it do it at, can you feel it heasitating, does it cut out??
Old Sep 27, 2013 | 01:16 AM
lemasters f100
Auto, not sure rpm don't have a gauge probably around 3-4000, sometimes it does hesitate when I'm pushing the gas pedal
Old Sep 27, 2013 | 07:31 AM
cigarxtc's Avatar
cigarxtc
Does it do that only when there is a load on it in gear? or will it do it when sitting in neutral/parked, with the engine revved up?
Old Sep 27, 2013 | 08:35 AM
lemasters f100
More noticeable when driving. Can barely hear it at idle
Old Sep 27, 2013 | 09:21 AM
lemasters f100
I tighter the battery terminals thi mornin because it would not start and then when I started driving the problem suddenly stopped.
Jimmygreco
Mar 11, 2015 08:47 PM
UawMan
2004 - 2008 F150
20
Jun 8, 2004 09:50 PM
ceads
Modular V8 (4.6L, 5.4L)
Aug 24, 2003 11:00 PM
lobo4me!
1997 - 2003 F150
Feb 14, 2003 02:12 PM
