Kill Switch Installation
Old Nov 24, 2007 | 12:16 PM
tamaleman's Avatar
tamaleman
I have a 1964 PU and need to install a simple "Kill Switch"...I had one in my old "54 Ford but it has been a long time and I am not quite sure what the steps are.
Old Nov 24, 2007 | 12:17 PM
tamaleman's Avatar
tamaleman
Old Nov 24, 2007 | 01:02 PM
matt2491's Avatar
matt2491
Wall switch wired into the ignition. Screwed under dash.
WORKS GREAT. Flick it up, turn the key to start, and you're running. When you want to stop, just flick it off.
Old Nov 24, 2007 | 04:21 PM
jowilker's Avatar
jowilker
http://farm3.static.flickr.com/2080/...54747953_b.jpg WORKS GREAT. Flick it up, turn the key to start, and you're running. When you want to stop, just flick it off.
You are an absolute genius. I would never have thought to do that.
Huge photo to boot too.
John
Old Nov 25, 2007 | 09:28 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
tamaleman
Welcome to (FTE)!
When I have wired a kill switch in the past, I tapped in to the power wire that
runs to the coil wire.
Works well for me, just my 2 cents!
Wally Womack
Old Nov 25, 2007 | 06:55 PM
iiizman's Avatar
iiizman
I used a small switch and wired a spdt relay off the ignition switch wire. Its easy to install and hide.
Z
Old Nov 25, 2007 | 07:49 PM
gustav129's Avatar
gustav129
Wow, that wall switch looks pretty hokie, yet very simple. I didn't even see it at first. That's almost as bad as a tupperware container used as a fuse panel box I saw in a Scout once.
Old Nov 25, 2007 | 07:55 PM
matt2491's Avatar
matt2491
Has never failed.
Old Nov 25, 2007 | 08:01 PM
matt2491's Avatar
matt2491
Has never failed.
Old Nov 25, 2007 | 08:28 PM
Rosati's Avatar
Rosati
This is not the kind of information we need to be sharing. It is not the proper method of doing automotive electrical and poses a risk of an electrical fire.
I would suggest using a device intented for the purpose rather than the provided picture.
The following link provide appropriate devices
Universal Ignition Switches
Please don't suggest things like this in the future. That's what the Chebby sites are for!
Old Nov 25, 2007 | 08:33 PM
matt2491's Avatar
matt2491
Come on, a little redneck truck engineering is always fun!
Old Nov 25, 2007 | 09:54 PM
gustav129's Avatar
gustav129
All I can say, "It looks good from my house."
Old Nov 25, 2007 | 11:45 PM
frty7ford's Avatar
frty7ford
What are you trying to accomplish with the kill switch?? If you are just trying to make it harder to start and easy to hide a simple togle switch on the ignition feed wire works great.
the house hold switch is not going to cause a fire. it is not something I would ever use unless I was stuck in the middle of nowhere and could not find anything else to get me home but it sure beats the heck out of No switch which could pose a fire problem.
Skorpion007
Jun 15, 2020 10:01 AM
fzeed
13
Feb 18, 2009 04:06 PM
mosilvers
Mar 5, 2006 09:20 PM
RJLB
Electrical Systems/Wiring
Apr 14, 2002 02:25 PM
mocky
Apr 11, 2000 11:37 PM
