What years are compatible?
Old Nov 23, 2007 | 06:04 PM
briang92205's Avatar
briang92205
Just took my brothers explorer after the knucklehead seized the motor and I'm wondering what years are compatible with 2000.
Also what size socket do I use so i can pull the front seats it looks like the kid threw a garbage bag in there and rolled the thing over a cliff
Any and all help is appreciated
Old Nov 23, 2007 | 07:33 PM
4.0 Beast's Avatar
4.0 Beast
Generally speaking, 1995-2001 Explorers are the same, they are the "Gen 2" models. This depends however on engine type, drivetrain type, and so forth.
Engine wise, 1998-2001 will be identical, as well as 95-97 versions.
There were some minor changes between the 97 and 98 years, looks and engine changes to be specific.
Old Nov 24, 2007 | 09:40 AM
mrshorty's Avatar
mrshorty
Do you know which engine? Are you looking for an exact replacement or are you considering a different engine?
Old Nov 24, 2007 | 11:36 AM
mediaman67's Avatar
mediaman67
actually 95-97's could have used 2 different 4.0L engines - the newer 4 was first used in the 97, and this was the year that ford phased out the original 4 OHV
but, that is a good question to add to his - can you use either in any of the Gen2 explorers? also how about the V8?
I need new heads for my 4.0L OHV - and it would be the same cost to just do an engine replacement from the boneyard - so, I'm wondering.... Love to shoehorn a V8 in there... :-)
Old Nov 24, 2007 | 09:47 PM
briang92205
It's the xls model 4.0 motor auto 4wd etc.
Would like the v8 but I don't have all the tools to modify the mounts.
Old Nov 24, 2007 | 11:11 PM
mrshorty's Avatar
mrshorty
Do you know which 4.0 V6? The OHV was the standard motor used at least until '98. In '97, ford introduced the 4.0 SOHC as an option. Later they dropped the OHV and made the SOHC the standard engine in Explorers. The switch occurred somewhere near 2000, but I'm not sure which year.
So basically it boils down to this. If you have the SOHC, you'll be looking for a '97-'01 4.0 SOHC. '02+ SOHC's might also work, I'm not sure. You might consider having the timing chain tensioners updated before you install the engine.
If you have the OHV, you'll be looking for a '95 to ?? OHV.
terrypearson
Jul 30, 2023 04:43 PM
quasarRIDER
Nov 27, 2016 01:22 PM
truckerdude69
May 10, 2015 10:22 AM
str8piped79
1978 - 1996 Big Bronco
Jan 27, 2011 10:58 AM
jay3403
May 19, 2009 11:11 PM
