LED Bulbs
Old Nov 23, 2007 | 01:22 PM
flareside_thunder's Avatar
flareside_thunder
LED Bulbs
I bought some LED bulbs and put themin the tailights on my 95 in my sig...Now the turn signals don't work.I heard something about soldering resistors inline with the wiring to the bulb itself.....is this true and which wire do I solder the resistor onto?Also...how big of a resistor?Thanks.
JR
Old Nov 23, 2007 | 03:15 PM
fordtruckman's Avatar
fordtruckman
i added LEDs in my taillights and had the same problem so what your gonna have to do is go to autozone or advanced auto parts and buy a LED load resistor no sodering you just clip it onto the wires
as for the wires to clip onto im not sure
Old Nov 23, 2007 | 03:46 PM
Franklin2's Avatar
Franklin2
Sometimes an electronic flasher will fix the problem. And you can use the resistors if an electronic flasher is not available for your truck. The resistor will hook in parallel with the bulb. So for the bulbs in the rear, you will have a brown wire for the running lights, and a colored wire for the brake/turn. You hook one end of the resistor to the colored brake/turn wire, and hook the other end of the resistor to the black ground wire.
If you want to know more about, it just punch in "LED load resistor" in a google or yahoo search box.
Old Jan 25, 2008 | 06:17 AM
O1COBRA's Avatar
O1COBRA
Just found this post. I jsut installed the LED taillights as well and now my turn signals go really fast. Will the resistor slow them back down to normal speed?
Old Jan 25, 2008 | 09:16 AM
Franklin2's Avatar
Franklin2
Yes, the resistors will make the flasher think the regular bulbs are in place.
Old Jan 25, 2008 | 10:49 AM
O1COBRA's Avatar
O1COBRA
Thanks Franklin!!!
Old Jan 25, 2008 | 07:10 PM
O1COBRA's Avatar
O1COBRA
Hey Franklin, I went to a bunch of different stores today and finally ended up at radio shack. They had resistors but to tell you the truth I dont even know what to look for or how to go about putting it in. The guy at radio shack had no idea what they even were. Can you give me a description of what I need to get and what to do with it? Thanks
Old Jan 26, 2008 | 12:00 AM
Franklin2's Avatar
Franklin2
Here's one.
http://www.eautoworks.com/html/ORD-1-1-1-33226.cfm
You need to wire one side to the bulb, and the other side to ground. The bulb will have a brown wire and a colored wire going to it. Hook the resistor to the colored wire, this is the brake turn wire. The brown wire is the running lights, and they do not need a resistor.
Old Jan 26, 2008 | 10:13 AM
Don Senkow's Avatar
Don Senkow
Grote makes a flasher for LED bulbs. They are available in 2 or 3 terminal styles. NAPA P/N GRO 44891 is the 2 terminal type. (See NAPA Online) We have used these and was a quick fix....Don
Old Jan 26, 2008 | 11:52 AM
flareside_thunder
Thanks for the PN Don....and thanks for the info Franklin.Later On
JR
Old Jan 26, 2008 | 10:05 PM
mhg's Avatar
mhg
as don said
just change the flasher
the factory flasher has a bulb out feature that
causes the fast flash when the load is low
get the flasher without this feature
in my 96 e350 I put 2 led 3157? in each side
I could not find the correct 3 blade like the factory put in
I used a 2 blade electronic unit and it wirks just fine
Dan Kacz
Electrical Systems/Wiring
Feb 27, 2017 10:41 PM
bobs 80 f250
Jul 24, 2016 09:35 PM
perljammike
Jun 16, 2016 09:50 PM
jgwatson109
General Automotive Discussion
Mar 23, 2016 10:08 AM
ghunt
Feb 5, 2010 05:36 PM
