LED resistor question
Old Feb 5, 2010 | 12:44 PM
ghunt's Avatar
ghunt
If you are installing a resistor to fix the flash rate for LED turn signals, can you split the "hot" wire on a resistor and wire the one resistor to both bulbs?
Old Feb 5, 2010 | 02:45 PM
JimsRebel's Avatar
JimsRebel
I would tap into the downstream side of the blinker can, it is in the fuse box on my truck.
Is there an electronic blinker can that does not use current flow for the blink rate?
Jim
Old Feb 5, 2010 | 02:52 PM
Slippery750's Avatar
Slippery750
Jim
+1 They do make flashers for low current draw. This is the easiest fix and if you change back for some reason temporarily (ie broken light) it is easy to change back.
Old Feb 5, 2010 | 02:54 PM
Slippery750
In theory, no you will be giving power to all turn signals this way (right and left).
Old Feb 5, 2010 | 05:36 PM
fmc400's Avatar
fmc400
MSEE
You're right, but I was assuming he meant "both" bulbs as in both the front and rear on one side. Either way, I think an electronic flasher would be the way to go for this.
bobs 80 f250
Jul 24, 2016 09:35 PM
perljammike
Jun 16, 2016 09:50 PM
jgwatson109
General Automotive Discussion
Mar 23, 2016 10:08 AM
flareside_thunder
Electrical Systems/Wiring
Jan 26, 2008 10:05 PM
bivens1172
Apr 27, 2005 12:17 AM
