Fuel filter drain help
Old Nov 22, 2007 | 12:47 PM
PaulJB's Avatar
PaulJB
I have a 1999 7.3 with 231000 miles. The water purge valve line is leaking fuel at cold start. I changed the fuel filter and purged the bowl. It still leaks, It seems to stop once the truck has warmed up. Thanks if anyone has any suggestions
Old Nov 22, 2007 | 02:36 PM
ernesteugene's Avatar
ernesteugene
That valve has two O rings that have issues with the new ULSD fuel. Ford sells a complete kit including the two piece valve and handle, two O rings, and 4 mounting screws. Others just find some new O rings, and only replace those.
Old Nov 22, 2007 | 02:58 PM
ron's power stroke's Avatar
ron's power stroke
welcome to FTE like Gene said..it's the oring behind the drain valve..you can get some here or cheaper on e-bay if you look around..i see some this morning..a set of 2 for 3 bucks..he also has the valve as well..this is just the orings..
http://www.dfuser.com/mfg/powerstrok...gs/O-Rings.php
and here is how you fix it..
http://home.centurytel.net/sabre/drainvalve.html
LB_
6.7L Power Stroke Diesel
Aug 1, 2013 10:37 AM
koski19
May 1, 2013 07:53 AM
artfd
Jan 1, 2012 08:13 PM
Ford Runner
May 3, 2010 07:42 PM
silly34
May 22, 2009 06:16 PM
