fuel pump removal
Old Nov 22, 2007 | 06:10 AM
trike1946's Avatar
trike1946
3 hours is nothing. How about trying to change the pump on a van? I had to take out the turbo and the fuel tower. You don't know how good you guys have it with an F series. Just changing an alternator on a van is a 2 hour job.
I don't know how true this is but I asked a Ford mechanic I know about what damage the tappet will do if it drops down into the engine when you pull the pump. He said it doesn't hurt anything, it just drops down and lays there. I never pulled the engine apart so I don't know. Does anybody know for sure what happens if it drops out? Wouldn't it lay on the cam?
Old Nov 22, 2007 | 06:48 AM
MADVAN's Avatar
MADVAN
Bob
Is your 96 a cali fuel system?
Mine is a E-350 4X4. I know how you feel. Topper is its a Cali fuel system in the van (97 on). Just did my peeping pump last week.
My Junk
http://photos.ford-trucks.com.com/sh...at=500&thumb=1
Bill
Old Nov 22, 2007 | 08:03 AM
origcharger's Avatar
origcharger
According to International if the cams pump lobe is in the position of maximum lift, the tappet can't fall down in the engine, it will rest on the cam lobe for easy removal. If the lobe is at the lowest position the tappet could fall down in the engine. So correct procedure is to remove pump bolts and lines and bar engine over till pump rises to its highest position for safe removal.
Old Nov 22, 2007 | 08:28 AM
skidford's Avatar
skidford
thanks a ton guys for all the great info and reading haha! im heading back to the garage right now.thanks again.
Tsisaman
2004 - 2008 F150
Mar 20, 2013 09:49 PM
wtroger
Feb 20, 2011 08:45 AM
40LUTZAG
1997 - 2003 F150
Nov 2, 2010 08:01 PM
rodneywar
17
Feb 3, 2010 03:51 AM
bassproguy07
Aug 20, 2006 09:13 AM
