Which Electric Fuel Pump
Old Feb 19, 2011 | 09:01 PM
wtroger's Avatar
wtroger
Which Electric Fuel Pump do you all recommend?
Old Feb 19, 2011 | 11:33 PM
catfish101's Avatar
catfish101
If I was going to run an electric pump I would use a Delco, a couple of parts numbers can be used. The pumps I am talking about were used on the 6.5's. They required the same fuel pressure the pumps on these engines do. I would set them up the same way. Use the 4lb oil pressure switch to kick in the relay for the pump while the key is in the run position and have it kick on during cranking. That system worked great for years.
Old Feb 20, 2011 | 12:05 AM
wreckinball's Avatar
wreckinball
you could easily wire up a mr gasket 12d to the ignition, provides the pressure needed and is made for diesel fuel, also inexpensive!!
Old Feb 20, 2011 | 04:09 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I had 2 Mr. Gaskets leak on me but they were bought about the same time and may have ben out of a bad "batch."
Old Feb 20, 2011 | 08:45 AM
wreckinball
very possible, not sure there, havent heard any complaints from my buddy that has two of them installed about a year ago. Still kicking away. I think that the bad batch thing is becoming more and more prevalent as parts and manufacturing are sent to the lowest bidder.
Aaron M Sholley
24
Jan 8, 2014 07:47 AM
Jgostrenga49855
Feb 7, 2013 06:36 AM
rickgthf
Nov 18, 2006 05:40 AM
GolferSA
Aug 29, 2003 08:43 PM
cobrajet
Nov 18, 2001 06:36 PM
