1978 - 1996 Big Bronco
bronco transmission problem ?
Old Feb 23, 2010 | 06:34 PM
bmacky14's Avatar
bmacky14
i got a 1990 ford bronco with the 351 windsor and a automatic transmission not sure wich tranny dont know much about automatics but its got enough fluid but clunks into reverse and sometimes drive hard and while driving it makes like a howl noise and sometimes will sound and feel like something is loose and moving around but it doesnt slip or hesitate i checked all the tranny bolts tourgue converter bolts and trany mount and there all good
Old Feb 23, 2010 | 06:40 PM
vtjvt's Avatar
vtjvt
check all your u joints
Old Feb 23, 2010 | 06:50 PM
andym's Avatar
andym
Also take the tension out of the driveline and check for play in the axle. It sounds like it could be a rear axle problem too.
Old Feb 23, 2010 | 08:18 PM
Encho's Avatar
Encho
The Southernmost Mod
Grab the cardon shaft and try to turn it with your hand, if your u-joints are bad it will have a lot of play.
Old Feb 24, 2010 | 10:50 AM
Kemicalburns's Avatar
Kemicalburns
the clunk into reverse could be either ujoints or the rear pinnion yoke is loose and needs tightend up.
do you have an OD button on your dash or end of shifter? when was the last time you performed a complete tranny fluid change and filter change?
Old Feb 24, 2010 | 12:31 PM
'96 Bronco's Avatar
'96 Bronco
You might also check your gears. My truck had a loud howling sound while driving down the road too. Turns out I had lost a gear tooth and was just flying around in the housing. Not good.
oh and x like 50 on checking the u joints
Old Feb 24, 2010 | 04:06 PM
Encho's Avatar
Encho
How do you tighten up the pinion yoke?
Old Feb 24, 2010 | 04:33 PM
Kemicalburns
there is a large nut on the end. they sometimes work loose. the haynes manual gives the torque spec for that.
Old Feb 24, 2010 | 06:25 PM
helirich's Avatar
helirich
When checking the u-joints and pinion yolk, besure to have it in netral. If the yolk is loose, you are supposed to change the crush sleeve. But I have seen and done it with out replacing it. If you have a yolk, you can hold it with a big pipe wrench and tighten the nut with a socket. If you have a disc yolk, you can put two bolts in and place a bar between them to hold it.
By the way, If your tranny has OD, it is a E40D.
Old Feb 27, 2010 | 09:28 PM
bmacky14's Avatar
bmacky14
so i checked all my u joints and tighten the pinion yolk up and yes it does have the overdive button but im starten to think that it is my differential because the howling has not only gotten worse but now its clunking really bad just when im drving not 100 percent sure yet tho
Old Feb 27, 2010 | 09:45 PM
Encho's Avatar
Encho
Oh yeah, i know what that is, you broke either the pinion or the ring. Open that differential, you'll see several broken teeths.
Old Feb 27, 2010 | 09:51 PM
bmacky14's Avatar
bmacky14
sounds fun ill check that tomorrow thanks for the help
Old Feb 28, 2010 | 07:43 AM
American Thunder's Avatar
American Thunder
8.8 rear.. heh
Old Feb 28, 2010 | 12:00 PM
'96 Bronco's Avatar
'96 Bronco
I just want to throw this out there...I told you so. ha That was what happened to me. It aint too bad to fix. and itll still run.
Old Feb 28, 2010 | 02:48 PM
bmacky14's Avatar
bmacky14
Ya sure enough nuttin but broken gears and chewed teeth now I'm just trying to find out what gear ratio it was
