it's been two weeks since I got my tranny rebuilt and today I got on it somewhat. Anyways, the truck was sort of sputtering like it wasn't getting enough fuel( Don't recall it doing this before the rebuild). My filter is newer but it is one of those that is close to the carb and the filter is only like two inches. Would a larger filter help me or is this possibly something else. ( also, the carb, fuel pump were replaced two months ago).
TIA,
Mike
I have several filters on mine. One large one at the tank, 1 at the carb. If it did not do this before, check to see if the modulator hose is connected and not colasped. I had the rubber hose on mine get soft and colasped, and created a hole in the hose.
From the early 1960's thru 1972, Ford V8 trucks have a cartridge fuel filter inside the fuel pump. Look at your pump...is there a tomato juice sized can on it? If so...there a fuel filter inside. It rarely gets changed, because ppl don't know it's there. The can screws on/off.
"Tee" off at the carb with a pressure gauge in the cab and run it hard thru the upper rpm range under full throttle conditions like up a grade checking pressure as your motor may be demanding more fuel than the fuel pump is providing.
This is where a wide band fuel/air gauge in the system helps vs spending money on unneeded replacement parts only guessing. Jetting correct overall?
Add to this a tach and vacuum gauge as standard items on a gear headed daily driven truck.
I'm guessing this is a slush box, was it built to your motors output as well your intended use or the truck like stall and shift points?
Tranny and engine should work together helping each other as a miss match will not only cause frustration but a uneccesary hatred of your truck.
Filters don't regulate pressure. I assume the big one at the tank was catching the major particles(Like rust from tank) from reaching the pump, and the small one keeps the needle/seat clean in carb.
ahh what a great idea! i am running a small performance one right before the carburetor, and i removed the one inside the fuel pump. i am going to have to put that sucker back in there. dirt in my fuel pump does not sound like a good thing
There are rubber diaphrams in the pump(one way valves) and if something gets caught in them they will not pump(no suction/pressure). Not sure how many are in a stock pump, but a Holley mech. pump has three. BUT, if one gets stuck, it will definitely drop in pressure as it allows fuel to back feed.
If you don't want one in the pump, just put a small plastic one inline back at the frame where the tank line comes thru floor of cab. OR put it before pump where line comes from frame. It's not mandatory, but in the name of "keep it clean" it surely doesn't hurt.
The Carter mechanical pump with screws holding it together have two valves.
They look like 3/4" diameter freeze plugs with holes with a thumb tack shaped viton valve. One up the other down for a suction / pressure check valving.
The valve is inserted into a stepped bore with three sake marks to hold the valve in place in the pump casting.
I had a pump that would lean me out at random on the highway but would correct itself within seconds. This I saw on the F/A ratio gauge when it happened.
On a road trip it finally stopped the truck dead. Took the pump apart on the side of the highway and found that the pressure valve was out of its pocket it was never staked when assembled. Used a 3/8" tap as a center punch and staked the valve, assembled and on the road again in less than an hour. Good thing it was a screw together pump vs these newer crimped together pumps. I reported about this right after the 4th of July back in 2005. Strange things can and will happen.
