incorrect fuel filter.....
Old Aug 16, 2015 | 08:42 PM
anthonym92's Avatar
anthonym92
My 86 f150 5.8 with an edelbrock carb has a wix 33032 fuel filter. Everything is good but I think its getting clogged. Anyways not the issue. The issue is I looked at the oem filter and its way smaller and threads on. Mine is between two rubber fuel lines with hose clamps. Can I use a fuel injected fuel filter like the wix 33032 or a motorcraft fg-800A with the same setup? Doesnt look like I can go back to the oem one.....any help?
Old Aug 16, 2015 | 10:26 PM
Gary Lewis's Avatar
Gary Lewis
The OEM filters that screw into the carb were usually a very coarse filter and, in my opinion, are worthless. Any aftermarket filter that fits your hose size is a big improvement. I like to run the clear plastic ones so I can tell when they are getting dirty, which happens quickly with these old fuel systems.
Old Aug 16, 2015 | 10:30 PM
anthonym92's Avatar
anthonym92
Okay awesome then. Where do i get the clear ones at? A link online or a store i can go to
Old Aug 16, 2015 | 10:41 PM
Gary Lewis's Avatar
Gary Lewis
O'Reilley's has this one: WIX 33003 - Fuel Filter | O'Reilly Auto Parts. I don't know if it is the right size for your line, but they have it in other sizes as well. And most of the parts stores carry similar ones.
Old Aug 17, 2015 | 01:01 AM
anthonym92's Avatar
anthonym92
Okay thank you gary. Your awesome bro. Also this isnt related to this thread but can incorrect timing cause a engine to run lean?
Old Aug 17, 2015 | 07:07 AM
Gary Lewis's Avatar
Gary Lewis
No, timing cannot change the air/fuel ratio. The two systems are independent.
And, thanks.
Old Aug 17, 2015 | 08:32 AM
anthonym92's Avatar
anthonym92
Okay thanks bud
61 uni
Nov 22, 2008 08:20 AM
pcskies
Nov 9, 2008 05:23 PM
azfordf100man
Dec 7, 2007 12:44 PM
460_Sprout
Oct 22, 2004 06:26 PM
jeepin
Jul 5, 2003 03:07 AM
