jumpy and sticky tach problem?
Old Nov 19, 2007 | 10:47 AM
JeremyJ's Avatar
JeremyJ
i posted this last year and read of somebody posting the same problem in another post.
my 1994 xl 3.0 supercab 5-speed has 166,000 miles on her.
when i shift, the rpm's jump up alittle and then come down.
also when coming to a stop and put the truck in neutral ata stop, the tach comes down to about 1200, sticks, then goes down to 800 approximately.
i have check the throttle cable and everything seems unstuck.
i scanned the truck and got no codes.....could a bad IAC valve cause this?
thanks.
Old Nov 19, 2007 | 11:45 AM
Bear River's Avatar
Bear River
Former ******
A bad IAC can definately cause this problem. The engine is supposed to automatically rev up a little when you put it into a gear, this is to help prevent stalling. But if it is sticking, the valve may be gummed up. It is an inexpensive part, so after doing some simple tests to verify that it is the problem you can just buy a new one.
Old Nov 19, 2007 | 05:37 PM
JeremyJ's Avatar
JeremyJ
what simple tests can i do to prove that the iac is sticking?
i cleaned it last year and it never fixed the problem back then.
Old Nov 19, 2007 | 05:52 PM
Lead Head's Avatar
Lead Head
sometimes they get so gummed up they just can't be cleaned. IIRC, they cost between $60-120 new. You can try finding a friend with the 3.0 and convince him to borrow his IAC for a bit to see if that fixes your problem before buying the part
Old Nov 19, 2007 | 10:23 PM
JeremyJ's Avatar
JeremyJ
$45.99 at autozone, pretty cheap actually
Rusty_S
Sep 8, 2015 01:08 PM
AndysFords
Aug 3, 2015 04:34 PM
bcamill
May 31, 2015 07:59 PM
broncrider051990
Jul 9, 2013 02:21 PM
jantzelw
Apr 22, 2011 05:37 PM
