How do I test a tach
Old May 14, 2015 | 12:17 PM
bcamill's Avatar
bcamill
OK, 1983 Flareside F100 with 302. It has factory tach, but has stopped working. I have been rebuilding this truck and put in a new distributor and coil. When the truck is running I am getting 7 volts on the two right side points of the back of the tach. I grabbed another tach from the junk yard and no success. How do I test the tach itself to see if that is not the problem? Then, do I just test continuity on the green wire from the coil to tach. Am I missing a ground somewhere? Thanks
Old May 14, 2015 | 01:46 PM
1986F150six's Avatar
1986F150six
On the back of the factory tachometer are 4 terminals. You might remove the tachometer for testing purposes, so the test wires will be shorter.
"B" is battery [12 volts]
"C" is coil [negative side]
"G" is ground
"8" is a 2nd ground, which is required for correct calibration of tachometer when for a V8
Six cylinder trucks use the same tachometer, but do not utilize the 2nd ground. It normally is all taken care of within the wiring harness.
When replacing the distributor and coil, you may have left a wire disconnected. Look for the green wire which connects to the negative side of the coil.
Old May 24, 2015 | 11:50 AM
bcamill's Avatar
bcamill
OK, the tach tests fine. I put my voltage tester to the "B" while fully installed and get nothing. I assume it is just not getting any juice. Any ideas on how to trace this? Which wire from the plug in on the back of the cluster. Also. all other gauges work fine.
Old May 25, 2015 | 09:46 AM
JimsRebel's Avatar
JimsRebel
You could just add a wire, here is a photo
https://www.ford-trucks.com/forums/9...ml#post8307310
Jim
Old May 31, 2015 | 05:13 PM
bcamill's Avatar
bcamill
Jim
OK. i have C to the neg side of coil. I have 12 volt switched to B. I have G to ground. Is the 8 supposed to got to a regular ground. (same as G)? I tried that and nothing. I had the 8 to pos of coil, but not the correct reading.
Old May 31, 2015 | 05:41 PM
JimsRebel's Avatar
JimsRebel
"8" is grounded in your case as you have a V8 302, same as "G"
Is it reading anything?? or just a dead needle??
Jim
Old May 31, 2015 | 07:34 PM
bcamill's Avatar
bcamill
Jim
It is reading nothing. I have hard wired it like the forum you sent me. I am just not sure where to attach the 8. Is it somewhere on the distributor or the positive of coil?
Old May 31, 2015 | 07:59 PM
JimsRebel's Avatar
JimsRebel
Just connect 8 to G
patrick87
1997 - 2003 F150
May 28, 2020 08:21 PM
speed demon
Jun 29, 2008 01:17 AM
wayneF250
Oct 14, 2007 08:49 PM
Marc150
Electrical Systems/Wiring
Nov 13, 2004 09:11 PM
Mike W
Sep 14, 2002 01:29 PM
