6.0 Hpop
Old Nov 17, 2007 | 03:45 PM
ledsled96's Avatar
ledsled96
6.0 Hpop
Can anyone tell me where the HPOP Tube is on a 2005 6.0. I am having warm start issues and it seems to be consistant with everyone else. I have a Bully Dog programmer w/ outlook monitor, K & N filter system, banks high ram intake and a banks turbo back 4" exhaust system. The truck doesn't want to start for about 3 hours after being ran.
Old Nov 17, 2007 | 04:06 PM
blackhat620's Avatar
blackhat620
It is located under the intake manifold. Here is a link to the 6.0 bible in the tech folder. You will have to remove alot of stuff to get to it.
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://dan.prxy.org/Truck/6L_bible_h.../Page_040.html
http://dan.prxy.org/Truck/6L_bible_h...l/Page_03.html
http://dan.prxy.org/Truck/6L_bible_h...l/Page_04.html
Old Nov 17, 2007 | 04:10 PM
ledsled96's Avatar
ledsled96
Thanks for the link. Looks as though it's just under the turbo. Any way to test this thing before it goes into the shop? I'm afraid they are going to frown on the upgrades to the truck, maybe even not cover anything. Guess I'll prep myself for a shadetree fix. One other thing, after looking at the pictures, I thought of something. When I wait to start, it sounds like a fan kicks on behind the glove box. It's starting to sound worn out and sometimes doesn't come on. Could this be the pump I am hearing? Maybe it's going bad?
Thanks again for your help.
Old Nov 17, 2007 | 04:15 PM
blackhat620
Here is a TSB on it
http://www.ford-trucks.com/tsb/fullt...hp?tsb=06-17-6
Old Nov 17, 2007 | 04:18 PM
ledsled96's Avatar
ledsled96
Old Nov 17, 2007 | 04:20 PM
blackhat620
No, the oil pumps only work when the engine is turning. You are probably hearing the blower door cycling or the vacuum pump under the hood (passenger side) running.
Old Nov 27, 2007 | 04:39 PM
ledsled96's Avatar
ledsled96
Got my truck back today. They said it was a fuel injector seal/o-ring and the high pressure fuel regulator. Drove the truck to the post office and then to the store and had it towed at their expense back to the garage. Guess they just ate up their $106 I paid in a deductible for towing. I told them about the HPOP and they were kinda dumbfounded but said they would look at it tomorrow.
Old Nov 27, 2007 | 07:03 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Here's another link with some more info on the HPOP STC fitting and the fix.
http://www.forddoctorsdts.com/articl...icle-06-10.php
Old Dec 2, 2007 | 08:11 AM
ledsled96's Avatar
ledsled96
Well, just got my truck back and what do you know...the high pressure oil pump was replaced and whammo! Problem solved. Thanks for everyones help. The dealership was clueless until I mentioned what the problem may be. If it weren't for all your guys help, who knows how long it may have taken to be fixed. Now I need a new gear selector indicator, I have looked for it online through a lot of sites but I can't seem to find it. It's the indicator that shows what gear you are in on the 05 250. Thanks for your helps guys!!!
Loftatsea
Nov 6, 2014 03:14 PM
FireBaller74
Jun 11, 2014 12:52 PM
USMCveteran
Nov 14, 2013 08:53 PM
lsramek1
Sep 12, 2011 12:58 PM
rebelsouth76
Jun 17, 2007 09:07 PM
