I have an 04 F250 6.0L diesel and I'm replacing the HPOP. When I removed the HPOP there is oil still coming out of some port on the driver's side part of the HPOP placement. Is this normal? Thanks
X2 on the hmmmmm.I was going to install the dieselsite pump today and button this thing up.Now I'm spooked.Think I'll wait and see how this debate turns out.I can tell you that the discharge pipe on mine seems very wobbly where it attaches to the branch tube.I don't see any signs of rubbing on the cover but without checking the clearance you never know. Thanks Mark.
Josh,decided to take your advice and replace the discharge tube.Is this the part that I need? 3C3Z-9T2288-AA. I got this from a post from M-Chan from 2011 Thanks Mark.
