Is it ever too late to change automatic transmission fluid?
2002 Ford Escape XLT 3.0L Automatic 2WD
My wife's Escape has around 102k on the clock, and I'm almost sure that the transmission fluid has never been changed. It's not burnt by any means, but it could use a good flush and filter change, IMO.
I was wanting to do the "gentle" flush that alot of folks on here speak of, then take the pan off and change the filter.
Is this reccomended with the miles she has on it?
I've heard from a lot of local-yocal's (you know how that goes) that once a car reaches 100k and it has never had the fluid changed, you're asking for trouble if you do. They say it's best to just leave it alone.
Is this true?
Thanks for any insight!
Nightrain
Is this true?
Nightrain
Change it.
The reason those guys think you shouldn't change it is because IF you ahve some sludge or crap built up in the corners of the flow pathways, and IF the new fluid dislodges them instead of dissolving them, you COULD block off a passageway with the crap and starve part of the tranny of fluid.
But for my money, that's a lot of things that need to happen just right. You are far more likely to see the new fluid dissolve any deposits slowly and that can only help.
20 years ago I would have told you that changing the fluid now would loosen the sludge build up in your tranny and either cause leaks, or block something off, but things have come a long way in 20 years. Motors and transmissions don't seem to burn up the fluids as quick as they used to. I'd go ahead and change it. Just don't wait so long next time.
The Escape does not have a drain plug on the torque converter.
You can adapt the fluid change procedure below to the Escape:
https://www.ford-trucks.com/article/...nsmission.html
The part I don't know is which is in and out on the cooler lines.
Nightrain
10-02-2012 11:16 PM
John Olson
04-30-2012 09:17 AM
Nightrain
08-05-2005 11:41 AM
