Sponsored by: Real Truck
Battery Light
Old Nov 16, 2007 | 07:30 PM
built tough's Avatar
built tough
Battery Light
hey guys was just wondering if anyone new what may be causing this stupid thing to come on I know it isnt the batterys for sure and possibilitys on what may be causing it it goes on when you are just idaling and goes off when you rev it up
------ thanks for anyhelp
Old Nov 16, 2007 | 07:38 PM
99f350sd's Avatar
99f350sd
Bad alternator.. I would have it checked.
Old Nov 16, 2007 | 07:39 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
What vehicle? How old? Light on at idle and going out with increase in rpm usually means altenator.....
Old Nov 16, 2007 | 08:57 PM
redford's Avatar
redford
FTE Leadership Emeritus
You've lost one or more diodes in your alternator. At idle, the remaining diodes cannot put out enough voltage and current to keep the battery charged, which is why you see the battery light.
Old Nov 17, 2007 | 03:31 PM
built tough
is it possible to just change the diodes or do you have to go with a new alternator
Old Nov 17, 2007 | 08:36 PM
Hootbro's Avatar
Hootbro
New alternator.
Old Nov 17, 2007 | 10:46 PM
BillyBob69's Avatar
BillyBob69
They do sell a diode bridge but the hassle itsn't worth it. get a new alt.
Old Nov 17, 2007 | 11:28 PM
ryaneverk2's Avatar
ryaneverk2
I'll third, or fourth or whatever number we're on... new alternator!
Seems like the most common cause for the batt light in these trucks.
Old Nov 18, 2007 | 12:24 AM
built tough
well now we r curious on something with it we thought it was the alternator but now wen you just open the hood it will sometimes shut off or if you wiggle a wire s0o we are second guessing but i think it may be just a fluke for it to shut off
Old Nov 18, 2007 | 12:50 AM
ryaneverk2's Avatar
ryaneverk2
Another thing to always check if you're having a charging issue is the battery and starter cable connections. Make sure they're all good, clean, and tight. If there's a lot of corrosion built up, that can drop your current a bit, and a loose connection can cause intermittent problems.
slim613
Sep 2, 2014 11:09 AM
Deshane
Aug 3, 2006 08:55 PM
Rizzle
Electrical Systems/Wiring
Oct 20, 2005 07:53 PM
tcatt
Sep 22, 2005 06:02 PM
dunebuggys
Feb 20, 2002 12:14 PM
