Service Code 741 what could it mean?
Old Sep 22, 2005 | 08:05 AM
tcatt's Avatar
tcatt
I have a 97 explorer 4.0 sohc, 2wd, O/D light is flashing, (indicating a transmission issue). Had a ford mechanic read the code.
He said it shows 741 and could be several different things that cause this code. I have not had a chance to let him have it for repair.
Any suggestions?
Symptoms: truck runs fine....every once in a while...very intermittedly...this o/d light starts flashing...truck then shifts very hard but seems to run fine once the tranny go through gears.
When the o/d light not flashing everything seens normal.
If you disconnect the negitive battery cable and reconnect.... the o/d flashing goes away. It may go for a week in all kinds of driving conditions...then it will come on again and may stay on for a day or so then may go away without removing the battery cable. I am afraid this will only get worse with time.
Thanks for any help.
Just gave truck to college son out of town and need to make sure that this will not strand him.
Thanks,
Tcatt
Old Sep 22, 2005 | 12:06 PM
87 XLT's Avatar
87 XLT
P-0741 is "Torque convertor clutch system improper mechanical performance."
The convertor clutch locks at about 40 MPH to prevent slippage & at idle it is unlocked to permit idling in gear.
Sounds like it needs a new lockup solenoid.
Old Sep 22, 2005 | 05:35 PM
tcatt's Avatar
tcatt
87 XLT,
Is this something that a weekend warrior mechanic can handle. Is it a simple drop pan, replace solenoid, replace filter, and fluid?
Thanks,
Tcatt
Old Sep 22, 2005 | 06:02 PM
87 XLT's Avatar
87 XLT
I only drive manuals, so I dont know much about the silly automatics.
But if the lockup solenoid is the problem I think it's a simple swap.
Take a look at www.autozone.com, enter the info for the Explorer and you should be able to find online instructions for swapping it.
Good luck with it.
thomas910
1983 - 2012 Ranger & B-Series
Mar 18, 2013 09:45 PM
Brother Les
Jul 19, 2010 01:44 PM
JP02XLT
Feb 13, 2009 01:27 PM
sorensenj
Jan 17, 2004 07:16 PM
