1978 - 1996 Big Bronco
How to read ABS codes?
Old Nov 15, 2007 | 07:53 AM
alz's Avatar
alz
My ABS light stays on constantly in my 95 Bronco. Is there a way to retreive these codes like the check engine light?
I've got a bad shudder throughout the truck while braking.
New rotors(also turned), ceramic pads(new), bearings and seals all good, radius arm bushings(replaced), balljoints(replaced), and tires(10,000 miles balanced).
Does this sound like rear brake problem?
Old Nov 15, 2007 | 04:35 PM
THE KING's Avatar
THE KING
Did you do the rear brakes? Also has the light aways been on or did it just start?
Old Nov 15, 2007 | 06:08 PM
alz's Avatar
alz
This is a plow truck for my business and is stored for most of the time during the summers. No, I have not done the rear brakes as of yet. The light started coming on intermitently about two years ago, and is now on constantly as soon as you start the truck.
I'm going to check the VSS tomorrow and maybe pickup a new one of those. If I could maybe read the codes, I would have a better guess as to what the problem is. I don't believe that the ABS is even functioning right now. I guess since the light is on, that's kind of a given.
Old Nov 15, 2007 | 06:50 PM
THE KING's Avatar
THE KING
Does your cruise control work? Search the forum for "ABS CODES" Im sure you will find the web site that tells you everything.
Old Nov 15, 2007 | 06:55 PM
THE KING's Avatar
THE KING
There u go i did it for ya. this site will tell u wut to do. Its fairly simple. Does your truck have an OBD2? I think they put em in 96 and above but i noticed you have MAF. Heres the site and check it out. http://www.fordfuelinjection.com/
Old Nov 15, 2007 | 07:18 PM
alz's Avatar
alz
The Bronco is 95, OBDI. I'l check FFI out but I think I checked and they didn't tell how to retreive ABS codes. Only CEL codes.
Old Nov 16, 2007 | 07:52 PM
alz's Avatar
alz
I pulled the codes, jumpered the orange/black wire and black wires. I got codes (2) and (5). Any idea what these mean or where I can find the definition of the codes?
Old Nov 17, 2007 | 11:32 AM
BroncoBrad's Avatar
BroncoBrad
ABS sensor
I have an '88 full size, don't know if it has similarities. I had same problem with the monkey light on the dash. Intermittent at first and then it stayed on. Although my brakes were in good shape and I had no braking problems. I could stand on them at 50 and the ABS worked fine, I checked.
I have an ABS sensor mounted on the top of the rear axle housing. Replaced that, problem gone. Just maybe, hope I could help.
BB
Old Nov 19, 2007 | 07:04 AM
jem270's Avatar
jem270
I don't have my 88 manual but this is for a 92 which should be the same.
2 = Open isolate Circuit
5 = System Dumps too many time in 2wd. Condition occurs while making normal or hard stops. Rear brake may lock.
Old Nov 19, 2007 | 08:16 PM
alz's Avatar
alz
Thanks, I have a 95 Bronco.
Do you have any advice as to how I go about fixing these two problems?
Old Nov 20, 2007 | 07:33 PM
jem270's Avatar
jem270
I can't seem to post pictures. Just look through my photos and you will find the ones about 2 and 5 flashes.
http://www.supermotors.net/vehicles/registry/9036/27523
Old Nov 21, 2007 | 08:11 AM
jem270's Avatar
jem270
You can send me a PM if the pictures don't post.
Old Nov 21, 2007 | 04:49 PM
alz's Avatar
alz
Thanks, when I get a chance I'll check those out. I was able to read them, just don't have time to check it out right now.
spinedoc
Aug 9, 2013 04:13 PM
redsly
1997 - 2003 F150
Jul 10, 2012 08:22 PM
zrt600guy
1983 - 2012 Ranger & B-Series
Feb 14, 2012 04:10 PM
4.0 Beast
Apr 2, 2011 08:40 AM
Joks79
Aug 23, 2010 06:37 PM
