DPFE sensor location?
Old Nov 13, 2007 | 02:49 PM
Flexfuel-Dave's Avatar
Flexfuel-Dave
I have a 1999 Ranger 4WD with the 3.0 Flex fuel motor. The truck also has ABS. I’ve got the CEL lit up on the dashboard. After a scan that typical 0401 code showed up.
I have a new sensor in hand. Where is the sensor located in the engine compartment? I did a search here and looked at a lot of posts, but I failed to find its location mentioned. I looked quickly under the hood and could not see anything like it attached to the firewall.
After I locate it would it be best reached from under the hood or up from the ground?
Some of these sensors can be elusive. I remember reaching deep to change that oil sending unit a few years ago.
Thanks, Dave
Old Nov 14, 2007 | 03:39 PM
Flexfuel-Dave
I'm all set!
Found it staring at me on the upper intake.
I was under the impression that it was located along the firewall or the engine bay.
Old Apr 4, 2009 | 10:36 AM
voltman0's Avatar
voltman0
thanks to the internet research ,i saved myself a bunch of money ,i too had a code insufficent air flow to egr but decided to look online at varioud posts and discovered that most of the time it is the sensor and sure enuff that fixed the problem,I have a 98 ranger 3.0 and the sensor is right up front and easy to change
chris20474
26
Aug 21, 2011 07:04 PM
meier63
Jan 25, 2011 07:32 PM
davelength
Nov 16, 2010 05:29 PM
Flexfuel-Dave
Mar 26, 2007 05:34 PM
Dave85zxt
Jan 7, 2004 04:16 PM
