What cause's a bent Pushrod?
Old Nov 13, 2007 | 12:50 PM
Customcab's Avatar
Customcab
I have dealt with this problem twice; it seems that a exhuast pushrod in my number six chamber is bent. The heads are factory 302 off a 76 motor. The lenght of the rods where a initial question and they are 6 7/8" long. I was thinking they where too short and that is what cause the rod to get damage. However new ones are the same lenght; Could the valve just be inoperable and that cuase it to bend the pushrod?
Thanks from a Shade Tree Mechanic with alot of leaves missing..
Mitch
Old Nov 13, 2007 | 02:36 PM
slinger34's Avatar
slinger34
Stuck or sticking valve? Is the motor stock or did you put a different cam in it.
Old Nov 13, 2007 | 03:44 PM
baddad457's Avatar
baddad457
Wiped cam lobe will do it too. Also pulled out rocker studs, that's a definate possibility with your heads
Old Nov 13, 2007 | 04:47 PM
Customcab's Avatar
Customcab
Thanks for your replies; I guess I owe you more info; the motor is recently built with bore 60 over; 10:5:1 flat top piston; mid 268 pro comp cam; & 650 carb. I'm getting the heads rebuild as we speak; but my buddy & I are both baffle on why the push rod bent; initially thought the guy who built my engine use the wrong size p-rods; but I check mine & the ones at a-zone and it calls for a 6 7/8" lenght. Hope this helps you guys determine my problem. The heads are having a 5 angle valve job; milled & stainless valve and brass seats; as I'm told. Its alittle more data than what I understand (not that knowledge on the head jar-gun) from my buddy who's builting my heads.
Mitch
Old Nov 13, 2007 | 07:25 PM
slinger34's Avatar
slinger34
Are you getting screw in studs on those heads? IT wuld be a good idea, any change in valve train geometry will casue havoc.
Old Nov 13, 2007 | 07:31 PM
baddad457's Avatar
baddad457
Pushrods usually get bent when the rockers get loose. You could also have had a rocker adjuster nut back off. Or if your heads still have the pressed in studs, bigger than stock cams will work them loose. Sight along the tops of the studs and see if any are taller than others. If they are, that's the problem.
Old Nov 13, 2007 | 07:42 PM
Customcab's Avatar
Customcab
Guys; thanks for your techinical advise; I will print a copy of this knowledge and pass it along to my buddy. I also thought loose rockers would be the reason; also I thought these heads would need adjusting during initial crankup and running once on the engine as well. But my buddy stated the rockers are the type you just tight down and no adjusting needed? the mechanic that built my engine also place about a 1/8" thick washer on each rocker stud; which seem out of place to my buddy; it could of been the reason as well; seems the washer was place to close the gap between the rocker & the rod; but we can't figure out why he would do this.
Again thanks and I'll post any other info as soon as I find out.
Mitch
Old Nov 13, 2007 | 09:13 PM
baddad457's Avatar
baddad457
Sounds to me that you've still got the pressed in studs. They would be the "positive stop" type in which you do torque the rocker nuts down and forget about them. The washer was an attempt to keep the nut from bottoming out on the stud shoulder and give you some room to adjust the lifter preload. Either the nut worked it's way loose, or more likely the stud started pulling out of the head from the extra force applied with the new cam profile and springs.
Old Nov 14, 2007 | 12:38 AM
Beanscoot's Avatar
Beanscoot
I once bent a couple pushrods by installing them on the edge of the lifters instead of in the center of the lifter. This was on an old Cadillac motor though, I don't know if it can be done on a small block Ford.
Old Nov 14, 2007 | 05:08 AM
HemiEater's Avatar
HemiEater
the only reason I have seen anyone put washers under the rocker nut is it take up clearance in the rocker. Evey time it was the cam that was junk and was causing the clearance.......
I would pull all the washers and check the preload (you should have 1/2 turn before the nut hits bottom)
my bit is the washers took all the preload out of the lifters and the valve hit the piston bending the rod......
who's idea was it to put washers under the rocker nuts..?????
get a new mechanic!
Old Nov 16, 2007 | 03:33 PM
Customcab's Avatar
Customcab
I'm with ya Hemieater; the guy who built my engine; is waiting for a bunch in the face from me; cost me time & money & potential future damaged to my truck; lucky I got a good friend who's only hobbie beside racing mustang's is builting performance heads. He too stated it doesn't make scense to put washer on the heads; I believe the exhuast valve p-rod was / got loose and cause it to bend the rod. Hopefully before eating Turkey I'll have my heads back on my truck. The truck is the one in my gallery if your interested in seeing it.
Mitch
BADASS 65 RANCHERO
Mar 27, 2014 12:33 PM
quaallen
Offroad & 4x4
13
Feb 23, 2011 02:18 PM
peepinu
Sep 5, 2009 05:59 PM
fordman428
Aug 30, 2004 09:02 AM
cruzintld
Feb 7, 2004 05:40 PM
