312 bent push rods
Old Jan 26, 2004 | 08:06 PM
cruzintld's Avatar
cruzintld
Question 312 bent push rods
I am getting a 1962 ford unibody truck on friday have been wanting truck since I was 17. Am 33 now. Anyway the truck has had several motors since purchased. The last being a 312. My uncle ran the truck a few years ago it bent a pushrod. He recently changed the push rod but has not run the truck since. Dad picked it up and is bring it here. I need to know what is causing the problem and everything I have read is not helping. Any good advice or sites, books anything would help. Thank you.
Old Jan 27, 2004 | 07:04 AM
IH Willy's Avatar
IH Willy
There would have to be some binding in the valve guide or rockers. The push rod bends when it cannot make something else move, usually a stuck valve.
Old Jan 27, 2004 | 06:18 PM
57_ford's Avatar
57_ford
Let me add some more things to check. Some times these engins dont pump oil up to the rocker arms and the rockers will get tight and bend a push rod. Also these engines have solid lifters and if the valves are adjusted to tight they will bend the push rods. The valve lash should be set at .019 hot. Have fun with your new truck. And let us know what you find.
Old Jan 31, 2004 | 12:20 AM
Wyoming10's Avatar
Wyoming10
I had a 360 in a 73 Ford pick up that bent a pushrod from backfiring one time. I replaced the pushrod and it ran great for years afterward.
Old Feb 7, 2004 | 05:40 PM
312's Avatar
312
a change to tubular pushrods might help.these are stronger than the old type.
Tinytune812
29
Feb 22, 2017 04:25 PM
rhino123
39
Jul 31, 2016 09:16 AM
kujo3692
Aug 12, 2015 12:10 PM
tommyt
Oct 30, 2014 12:20 PM
caroc1964
13
Sep 14, 2009 01:34 PM
