Stacks are too clean!!
Nov 13, 2007 | 10:08 AM
What are some cheap ways to get more black smoke?
Nov 13, 2007 | 10:14 AM
14.7k mod... fuel pressure shim... disconnect the turbo... get a dirty air filter...lmao don't ask...
Nov 13, 2007 | 10:16 AM
There aren't any. You need more fuel to create more smoke. I guess you could use a plastic bag and restrict your air filter. (kidding!). Joe has reported his ICP mod increases smoke but I don't recommend you do that before you have a pyrometer or you could end up with alot more smoke than you intended!! (read burned pistons!!!)
Nov 13, 2007 | 10:19 AM
yea i am thinking about the bag option... hehehe but when i restrict airflow it blue smokes more then anything...
Nov 13, 2007 | 11:45 AM
Nov 13, 2007 | 01:04 PM
Search 10K mod or coonhunterjoe 10K same mod two different versions
Nov 13, 2007 | 01:17 PM
I remember these days of "How do I make black smoke?" lol, it will come in time my friend. Once the bug bites ya, your in for one heck of a ride
I would recommend you do the coonhunterjoe mod, shim the FPR, and get ya a set of gauges and have fun with the truck
Cowboy Steve
Nov 13, 2007 | 02:20 PM
If he is askin' for more smoke then he is already bitten and infected. All he can do now is enjoy the ride.
Nov 13, 2007 | 02:38 PM
Well, can always do the windshieldwasher res w/pump inside, and oil trick....
Nov 14, 2007 | 10:12 AM
im curious about the windshieldwasherfluid resv. and oil trick. but i want balck smoke not white smoke. lol
Nov 14, 2007 | 11:45 AM
Basically you use a Winshield washer res that has a pump in it to hold oil.
You hook the out tube up to the exhaust someplace where it can basically burn off.
You can't hurt anything cause your just burning oil.
Then you hook a switch up to your dash to dump the oil into th exhaust.
Insta smoke screen. Be so badass to hit the the smoke screen button while dumping loads of black on everyone.
Nov 14, 2007 | 11:57 AM
wont that make white smoke?
Nov 14, 2007 | 12:03 PM
Of course.
But if you mix it with the carbon rich black smoke, it will be insane.
I'm sure there is something you can burn other then oil to get a diff color.
What color does ATF burn?
Nov 14, 2007 | 12:09 PM
Nov 14, 2007 | 12:16 PM
Dirty oil burns good and black. That is what I start the campfires with. Instant flame just can't get near it for a couple of minutes.
