Stacks are too clean!!
Old Nov 14, 2007 | 12:22 PM
powerstroke 96`'s Avatar
powerstroke 96`
wow i think that i have a problem.i often find myself watching u-tube videos of powerstroke Black smoke. Is that bad? i also have the earge to blow flames out of my stacks. i did it with my firebird but that was a gasser.
Old Nov 14, 2007 | 12:26 PM
Neal 97 250's Avatar
Neal 97 250
I have thought about that. Is it possible with diesel smoke. That would solve the emissions problems. No more unburned fuel. There you have it Al Gore, problem solved.
Old Nov 14, 2007 | 12:29 PM
powerstroke 96`
lol i was thinking about a small propain tank in my tool box with some harware store fittings an electric valve and an ignition system of some sort.
Old Nov 14, 2007 | 12:57 PM
Talyn's Avatar
Talyn
Flames are done with a fuel rich mixture and spark plugs, or propane.
Spark plug makes a good ignition on them.
Make sure you use a backup valve in the propane line.
So, now were up to diesel smoke, smoke screen and flames to boot!!!
Damn..
TJ, were putting your stacks back on and going crazy. I'll be over on .... friday about... lets say.. 3 oclock.
You can uh, skip church sunday. Were not stopping till were done.
Old Nov 14, 2007 | 03:00 PM
audimaster's Avatar
audimaster
http://cgi.ebay.com/ebaymotors/CUSTO...QQcmdZViewItem
Look through the pictures! Its got flames, in more ways than one.
Old Nov 14, 2007 | 03:06 PM
tjbeggs's Avatar
tjbeggs
thats the second time that truck has been listed (atleast!). It just doesn't do anything for me. it might be unique and have fancy paint but it is far from show quality.
Old Nov 14, 2007 | 03:23 PM
StrokeThis96's Avatar
StrokeThis96
i was wondering if that oil in a resovioir and pump actually works and looks like real black smoke, if so, where do u mount the res. and the outlet tube for the oil in the exhaust??
Old Nov 14, 2007 | 04:14 PM
Talyn's Avatar
Talyn
Yea, it actually does work.
Your exhuast is hot enough to burn oil. So you just pipe it in where it will be hot enough, just use some tubeing that wont melt is what you gotta do.
one squirt and lots of smoke.
It's old trick. but it will work.
I'm sure youve dripped oil on your manafold before. it burns off without issue and smokes a bit.
So pump in some dirty oil, and it will be pretty grey/black/blue
Old Nov 14, 2007 | 04:18 PM
StrokeThis96
wheres the place to mount to res. and wheres the best place to inject the oil in the exhaust? and i take it u just use a smiple pump for the oil?
Old Nov 14, 2007 | 09:02 PM
strokin'_tatsch's Avatar
strokin'_tatsch
how bout you just get a chip, injectors, then the oil trick, and then the propane ignitor in the stacks can you say... more black smoke than like 10 12valve dodges combined!!!!! hahahahahahahahaha!!!! this is pretty cool, but i don't think i wanna squirt oil in my exhaust.
Old Nov 15, 2007 | 08:51 PM
Talyn's Avatar
Talyn
anywhere its hot really
and you use a winshieldwasher rez that has a pump in the tank, so you dont have to use a seperate pump.
Dumping oil into the exhaust wont do anything bad, there is nothing that can go wrong, it will just burn up. If it doesn't burn up, it will just help prevent rust inside. haha.
I havn't done this mod, so i'm not sure on the specifics. Was somethign told to me, which should easily work.
Down by the x,y, or h pipe i would think, where its HOTTTT and its insta frizzles.
Old Nov 15, 2007 | 09:05 PM
tjbeggs's Avatar
tjbeggs
Why not just put used oil from your last oil change in the windshield washer reservior and hose your windshield with it. When you feel the need to blow smoke it the switch and majic presto your engulfed in black (just don't look out the side or rear windows!)
Old Nov 17, 2007 | 01:22 AM
  #28
cchildress's Avatar
cchildress
This realy interested me so I did it tonight and I think I need to make it a lil more flamable so Im guna add a lil diesel or gas and see what it does bc its not burning as I would like it to! But when it gets hot it is BLACK!!!!
Old Nov 18, 2007 | 01:49 PM
  #29
Talyn's Avatar
Talyn
you did the winsheildwhiper smokescreen mod!?
sweet!!!!!!
take pics!
I woudln't add gass. it explode.
But it should really only work when it gets hot. =)
Old Nov 18, 2007 | 07:31 PM
  #30
strokin'_tatsch
you could add some diesel, not gas. diesel makes black smoke when the fuel is not burned completely and in the exhaust all the fuel is not going to burn completely and will make black smoke. i would just stick with the oil though if your gonna dump stuff down the exhaust.
