1978 - 1996 Big Bronco
4LO light glows sporadically
Old Nov 12, 2007 | 01:54 PM
MaryfPoppins's Avatar
MaryfPoppins
Okay folks here is a weird one. "96 Bronco 4x4 shift buttons on the dash. With truck in 2wd the 4LO light will glow,not fully lit, as if I have a spook in my truck trying to get my attention. I put it in 4Lo, it goes in fine. Disengage and the light goes out, until the next time..... Any ideas? Not hugely concerned, just curious.
Old Nov 15, 2007 | 06:40 PM
greystreak92's Avatar
greystreak92
You've got a backfeed through wiring somewhere. My guess would be somewhere down around the shift motor where the harness is exposed to the elements and debris from the road. A small glow would indicate positive (+) backfeeding across the lamp filament to ground. The lamp should not illuminate until the electronic shift control module has verified the shift motor has engaged 4LO. In other words its not likely the problem exists in or near the switch itself unless you have wiring harness issues inside the dash.
Old Nov 18, 2007 | 07:24 PM
Black Ford XLT's Avatar
Black Ford XLT
Sounds like a wire may be grounded out as as i have had this problem with other sources good luck TR
Old Nov 20, 2007 | 05:09 PM
MaryfPoppins
Thankyou both for the help! When I finish tracing the idle problem it still has I will check out the wiring. I am posting the idling problem under the original post for '96 high idle, as this is a continueing saga... but we are making headway thanks to people like you.
bbdano
2004 - 2008 F150
Mar 14, 2016 03:21 PM
skaditalywink
Feb 13, 2015 02:52 PM
99ford150
1997 - 2003 F150
Jan 18, 2015 09:20 AM
PSDlongbox
Sep 17, 2013 08:20 PM
fused
Jan 17, 2005 03:12 AM
