Sponsored by: Auxito
4 lo engaging
Old Jan 17, 2015 | 06:16 PM
99ford150's Avatar
99ford150
4 lo engaging
I have 1999, F150 5.4L with electric 4wd shift ****. I put it in 4high just fine and smooth. Now 4lo on other hand rough shift if it goes in 4lo, sometimes won't engage but 4 high works fine. What's the cause
Old Jan 17, 2015 | 07:43 PM
Spotty's Avatar
Spotty
Is the transmission in neutral with your foot on the brake?
Old Jan 18, 2015 | 09:20 AM
steve(ill)'s Avatar
steve(ill)
you should be stopped, in neutral, or might need to roll the truck a foot to get it to engage........ If it JUST DONT WORK... then you have an electric motor on the transfer case that shifts from LO to HI and that is not happening.. Either stuck / bent/ motor problem/ wire problems.
Firefighter 1406
Dec 1, 2012 11:11 PM
ventureout350
Apr 20, 2011 08:49 PM
dallas lewis
1978 - 1996 Big Bronco
Jan 14, 2007 06:23 PM
hotrodfeguy
Nov 1, 2005 09:49 PM
