Sponsored by: Real Truck
snow plowing 4x4
Old Nov 11, 2007 | 07:14 PM
kupiec20's Avatar
kupiec20
snow plowing 4x4
did not know if you should plow in 4wheeldrive
Old Nov 11, 2007 | 07:17 PM
johnnysF350's Avatar
johnnysF350
I would in most circumstances..... Unless the snow is really light and you are cutting right down to the pavement...
Old Nov 11, 2007 | 07:49 PM
RogueSpear2023's Avatar
RogueSpear2023
Most guys around here plow in 4 wheel drive, I don't know why you wouldn't.
Old Nov 11, 2007 | 08:17 PM
hydro_37's Avatar
hydro_37
I run 4 wheel drive when plowing and also down the road between jobs. Only thing it hurts is gas mileage. I hardly ever use low lock plowing unless the snow is really wet, heavy and deep. Most storms it is in 4 wheel drive for 15-20 hours.
Old Nov 11, 2007 | 08:32 PM
marcs724's Avatar
marcs724
you won't plow much snow in 2wd. Along the same lines is this....should you use the two/haul while plowing? This is the first plow truck I've had with this option. I was guessing not to use this since it seems to take the tranny longer to engage when going between D and R, etc. Thoughts?
Old Nov 12, 2007 | 05:12 AM
chuck06250's Avatar
chuck06250
You don't need tow/haul for plowing. In fact, the owners manual recommends against it.
Old Nov 12, 2007 | 07:59 AM
bigblock_drock's Avatar
bigblock_drock
well it might make it easier to slow down in tow/haul mode b/c it will down shift and you wont need to hit the brakes and risking locking up the front tire?
Old Nov 13, 2007 | 12:42 AM
aldridgec's Avatar
aldridgec
I doubt at the speeds you will plow the downshift will make any difference.
unhcp
Oct 16, 2011 12:06 PM
LilRinn1019
Massachusetts Chapter
Mar 31, 2009 06:38 PM
FX4 5.4
Jan 17, 2009 11:00 PM
late70sfordnut
May 1, 2008 06:32 PM
Ryan T
1997 - 2003 F150
Mar 5, 2008 08:50 AM
