computer router help needed
Old Nov 12, 2007 | 07:20 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
Check each PC to see if they can see the router - it'll have a built in web server so you can open your browser and enter the IP. If the machine can't see the router, then the networking for that PC is most likely screwed up....
Old Nov 12, 2007 | 07:22 PM
andym's Avatar
andym
Originally Posted by Mil1ion
To see... means Identifies the computers on the network.
The Main computer with XP is not identifying the other 2 and the other 2 aren't seeing the XP .
Would the router contain the IP addresses of them all ?
It might, but it would be easier to go to each machine and run "ipconfig".
The output will look like:
C:\Documents and Settings>ipconfig
Windows IP Configuration
Ethernet adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnect
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : blah.COM
IP Address. . . . . . . . . . . . : 158.140.47.85
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 158.140.47.254
Note the IP address on each machine, and make sure that A and B can both ping C, etc.
Once they all have valid IP addresses, then make sure they're in the same workgroup (or domain, but probably not). Also make sure Microsoft file & print sharing is enabled for that network adapter.
Old Nov 12, 2007 | 07:57 PM
donjamer's Avatar
donjamer
Win 98 uses winipcfg instead of ipconfig..
You can also test them by searching for computer...
It is my guess that the XP machine is the culprit... Probably a Microsoft update or firewall setting...
XP usually automatically detects other PC's, printers, and shares in the workgroup..
Old Nov 12, 2007 | 08:01 PM
Mil1ion's Avatar
Mil1ion
I did the search numerous times
I'm think a firewall situation now.
Old Nov 12, 2007 | 09:47 PM
exiled's Avatar
exiled
Have you shut the firewall off yet they tried to connect? If you have and it did'nt help then just redo your network. I usd a flashdrive so now when I have a problem I can just redoit. You can haggle all night w/ your router and get now where. If you changed a routing table by mistake you cab stay lost.
Have you used the netstat -n yet?
Old Nov 13, 2007 | 09:25 PM
Mil1ion's Avatar
Mil1ion
It was my ISP firewall program settings.
I had everything so secure nothing was getting in >
all good now
cjben
13
Jan 27, 2009 08:02 PM
FordPickup460
63
Nov 20, 2005 09:41 PM
maticuno
Jan 20, 2005 06:45 PM
FAB150
22
Oct 25, 2004 10:18 AM
WhëëlMå1
Nov 29, 2003 03:34 AM
