help with some trouble codes and rough running.
Old Nov 18, 2007 | 11:15 AM
  #31
holiday187's Avatar
holiday187
just read codes and i have egr flow insuficient and misfire cylinder 7 and 4. I traed thewires back to the coil pck and those two wires are on the same coil pack. Wonder if the coil pack is going bad???
I cleaned the egr ports and now the egr flow excessive is gone. wtf???
Old Nov 18, 2007 | 12:01 PM
  #32
ronk1969's Avatar
ronk1969
most likely that coil is bad. if your not sure and depending on money go look for one at the junkyard.
Old Nov 18, 2007 | 01:27 PM
  #33
holiday187's Avatar
holiday187
I switched the coil pack from one side to the other. if the codes jump to diffrent sylinders then i have a bad coil pack. it's amazing that all this happened at once.
Old Nov 21, 2007 | 05:55 PM
  #34
holiday187's Avatar
holiday187
code stayed on cylider 4 and excessive egr flow. I'm starting to think that i should inspect the gap on the spark plug on cylinder 4 and 7.
Old Nov 22, 2007 | 01:21 AM
  #35
yardbird's Avatar
yardbird
If you are getting vacuum to the EGR at cold idle, then that is why you are still getting excessive EGR flow codes.
The running worse now is because with the ports clean, even more exhaust gas is passing through the intake than ever before, and at the wrong time.
This is probably causing the miss codes also.
The EGR solenoid sounds like it is bad.
As stated earlier, pull the vacuum line off the EGR. Plug this line. Find a way to apply vacuum to the EGR when you need it, even if you have to tee off of another vacuum line.
With the engine idling, apply vacuum to the EGR valve. If there is no change, then the EGR is probably bad also.
If you are using vacuum tapped from another source on your engine, keep the line capped until you hook it to the EGR to keep the engine from running lean and altering the test.
fabrication
Jun 25, 2019 11:08 AM
2oo1 4x4
1997 - 2003 F150
May 15, 2014 08:05 PM
4xFordFreak
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 6, 2007 12:03 AM
f1001978
1978 - 1996 Big Bronco
Aug 25, 2004 07:12 AM
poknox
Jun 3, 2004 07:10 PM
