Help!! Code 332 and nothing helps
Old Jun 2, 2004 | 06:08 PM
poknox's Avatar
poknox
I keep getting code 332, EGR valve opening not detected. I have replace the EGR valve, The EGR solinoid, the DPFE, the ECT, cleaned the EGR rail, and cleaned the MAF. When I drive it for about 2 miles the check engine light comes on . It will go off under high acceleration for a few min and come back on as soon as you start to cruise. I do not know where else to look. This is very frustrating. HELP!!!!!!
Old Jun 2, 2004 | 08:15 PM
dogman's Avatar
dogman
What year is your X???
Old Jun 2, 2004 | 10:39 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Poknox, I would look for a leaking vacuum hose somewhere in the EGR system. It sounds like everythings new, but there's not enough vacuum signal to operate. Maybe a hose has craked or come loose ........
Old Jun 3, 2004 | 06:21 AM
poknox's Avatar
poknox
My X is a 94. I will look for a leaking hose. Strange thing happened last night. We went to Sonic for supper. Sat in the X and waited Temp went up to mid range and light went off. Started for home and the temp gage started to drop to what we know as normal ( Just above cold in the normal range.). The light stayed out until it got back to what we know as normal. Could a stuck open thermostat cause this?
Old Jun 3, 2004 | 09:32 AM
thelonerangerxlt
It's possible. The EGR is not supposed to operate when the engine is in open loop/cold. Maybe the stuck open thermostat is confusing the PCM as to when the EGR is supposed to be operating??????
I previously had an erratic high idle with mine, and no MIL. It turned out to be because of a stuck open thermostat. Thermostats are easy and cheap to change, so it might be worth a new one just to rule it out. The stock Motorcrafts (made in Germany) seem to be failure-prone, so I would suggest a Stant brand for replacement.
Old Jun 3, 2004 | 06:03 PM
dogman's Avatar
dogman
It would be the cheepest place to start.
Old Jun 3, 2004 | 06:15 PM
dogman's Avatar
dogman
I ran the code you have and it said it was a knock sensor 2 circuit low input (bank 2). Need to check the code again.
Old Jun 3, 2004 | 06:24 PM
poknox's Avatar
poknox
My X is a 94. The Haynes Manual shows code 332 as beinf an EGR valve opening not detected.
Old Jun 3, 2004 | 07:05 PM
dogman's Avatar
dogman
I'd Call the dealer and ask about that code
Old Jun 3, 2004 | 07:10 PM
thelonerangerxlt
My Sunpro book says code 332 (OBD I) is "Insufficient EGR flow detected".
Dogman's definition is for a P0332 OBD II code (post 95 model year).
xc4jokestomper
28
Mar 3, 2011 09:36 PM
302VAN
Apr 13, 2008 05:39 PM
cablemaster
Sep 20, 2004 05:24 PM
Keith460
Jan 15, 2001 01:35 PM
