My experiences towing with the 2V thru the Big Horns and Rockies (~9700' climbs) would say that either would improve things but BOTH would be KILLER.
The 4 speed is 'okay' ... BUT 1st and 2nd are spaced WAY too far apart.
The 3V from what I hear from my buds that have them prefers a slightly lower RPM (3000) as the 'low' spot for power over the 2V (3200)...that makes a big difference when pulling heavy on a steep grade...
BUT I guess the torque shift with the tow/haul mode alone could be more beneficial...all I know is those extra ~22ft-lbs of torque and 52HP would be nice to have sometimes!...so for me it would be a toss up I guess as I see both having advantages...but BOTH together...man that would have been killer in the EX!!!
I'm like Monsta - if I had the choice I'd choose the Torque shift. I think the raw HP/TQ difference between the 2v and 3v are minimal - the HP/TQ 'at the wheels' difference is probably delivered from the Torque Shift tranny.
Nope, torqshift doesn't make the diff.....(tho torqshift by itself would be an improvment behind any of the engines vs previous tranies) ..traded a 2005 F250 5.4/torqshift for 2008 F350 V10/torqshift - big difference, and tranny is the same in both vehicles. & the V10 makes it's torque at a lower rpm. Speaking of which, anyone have a torque curve for the 3V V10? I heard/read somewhere that the 3V V10 puts out close to 80% of its rated torque just above idle. Like to see the torque curves for both 5.4 & V10 3 valve. Anybody?
Yep, that difference would be totally expected. But I still believe that if you were to take a two v10's, one with the 4r100 and one with the Torque Shift, you'd see a noticeable difference at the wheels. That's purely my opinion, I could be wrong... it happens on occaision.
