exhaust leak
Old Nov 9, 2007 | 01:08 PM
scottie2hottie's Avatar
scottie2hottie
exhaust leak
Are exhaust leaks common on these trucks? I have one coming from drivers side, seems to be coming from the front of the motor. How difficult is it to replace the gaskets? Should I go ahead and replace the whole manifold while I have it apart? Thanks in advance.
Old Nov 9, 2007 | 02:38 PM
Cuda_jim's Avatar
Cuda_jim
It can be a PITA to get to the up pipe bolts, other than that not to hard as long as nothing breaks. Soak the bolts/nuts with good penetrating. Squirt them warm, then again cold and then a couple more times.
Try tightening it. Could be warped?? If that's the case it can be machined flat again. Hopefully it's not cracked.
Gaskets, FEL-PRO Part # MS93489 about $20
Old Nov 9, 2007 | 02:50 PM
scottie2hottie
how much is this hurting my performance? Just need to know where at my agenda to place this project....
