fuel pump problems
Old Nov 6, 2007 | 06:09 PM
blueovalfan's Avatar
blueovalfan
fuel pump problems
I have a 91 F-150 straight 6 cylinder supposed to have dual tanks but front has been removed. Thought fuel pump was out, replaced it. still wouldnt kick on. Replaced fuel pump relay, still nothing. BUt i used a test light and grounded a wire coming off the relay and the fuel pump kicked on but wouldnt kick off untill i released the test light from the wire. Got a clue?
Old Nov 6, 2007 | 06:42 PM
ReadOrDie_DW's Avatar
ReadOrDie_DW
Isn't that what you wanted?
Old Nov 6, 2007 | 06:52 PM
subford's Avatar
subford
That is the way the computer controls the fuel pump (relay).
The computer grounds the coil of the fuel pump relay for one second when you turn on the key and it will ground it again when it sees a PIP train from the distributor. It will then remove the ground again one second after the PIP train stops or when you turn the key off.
Old Nov 6, 2007 | 06:55 PM
ReadOrDie_DW
Ok so he has the wrong relay then right? The fuel system isn't something I've had much trouble with yet (thank goodness)
Old Nov 6, 2007 | 07:07 PM
subford's Avatar
subford
He has the right relay but his computer either is not grounding the coil or he does not know that the fuel pumps do not run all the time the key is on with the engine not running.
Old Nov 6, 2007 | 07:46 PM
fordmancounty's Avatar
fordmancounty
he might want to check for spark and check the inertia switch. i think i have found my problem with mine.
Old Nov 6, 2007 | 08:08 PM
blueovalfan
I checked the inertia switch the button is not up. When i turn the key on the pump does not kick on , when i use my test light and ground one of the wires in the relay it makes the pump kick on . When I remove it the pump shuts off
Old Nov 7, 2007 | 06:01 AM
subford's Avatar
subford
Does the pump come on and run for one second when you first turn on the key and you do not try to start the engine?
By the way there is nothing wrong with your inertia switch or fuel pumps.
If they do not come on for the one second then you have a either a wire problem to the computer from the fuel pump relay coil or a bad computer.
Try grounding pin #6 of the DLC (test connector/VIP connector), turn on the key and see if the pumps run as long as the pin is grounded.
Old Nov 7, 2007 | 05:19 PM
blueovalfan
The pump does not come on by just turning the key on. When i grounded the #6 pin the pump did kick as long as the pin was grounded .
Old Nov 7, 2007 | 06:05 PM
subford's Avatar
subford
Sounds like you may have lost your computer.
But first check and make sure that the small black wire with a white (maybe green) strip near the batteries NEG post or at the end of the small black wire leaving the NEG post and screwed to the body is well grounded. This is the only ground for the computer and it must have this ground to run the engine.
Old Nov 7, 2007 | 08:37 PM
blueovalfan
The ground seems to be ok , where is the computer? Is it easy to change? I have never messed with the computer on any truck
Old Nov 7, 2007 | 08:54 PM
HMR-RSQ's Avatar
HMR-RSQ
Thumbs up PCM location
Heh dude having similar problems. The computer is located behind your left kicker panel. The bolt and connector is under the hood at the firewall
Old Nov 7, 2007 | 09:29 PM
subford's Avatar
subford
That is where its is at.
Old Nov 11, 2007 | 02:49 PM
blueovalfan
Thanks Subford replaced the computer today and it fired right up
dakota-boy
Electrical Systems/Wiring
Mar 14, 2016 09:29 AM
deanna197
May 28, 2011 08:21 AM
rquinlans
Dec 10, 2010 12:42 PM
czechster
Jul 10, 2008 06:50 PM
wvmac
Bronco II
Feb 10, 2003 12:35 PM
