Bronco II Ford Bronco II
86 Bronco II...fuel/start problem
Old Feb 7, 2003 | 12:18 PM
wvmac's Avatar
wvmac
Exclamation 86 Bronco II...fuel/start problem
My 86 bronco II died a month ago. Have fire but no fuel. Took pump off..tested pumps...they work, checked all grounds ( around battery also) and links, relays and fuses. All appear OK, clean and working. Last but not least, have replaced the brain(twice, thinking they must have given me the wrong one)...nothing. I called ford to double check cross ref #'s. I have power but nothing coming out the brain to the pumps and injectors. I tested wires with no shorts found. I did add ground to fuel relay and got pump working, pressure on the rail but injectors will not let fuel in...but pump will run all the time(high pressure) and its not suppose to....still not right. Even bypassed switch for injectors and got the truck running. This will not work though. Any ideas? Is there an ignition prob?...also replaced pick-up and button/cap. This has a lot of guys puzzled. Oh, the brain will not kick out my codes either? Not giving up!
Old Feb 7, 2003 | 06:45 PM
fordluver's Avatar
fordluver
I read this to my husband who put a motor in his '87 Ranger and had problem after problem. REady? Here we go!
Check the (crank sensor, cam sensor or tach wire) connection. If the connection is bad to one of those sensors, the computer wont get the reading that the engine is turning over. If it isnt sensing that the engine is turning over, it's not going to turn the injectors. It could have one of these 3 sensors, (check Haynes manual). I have an '86 B2, but we're not sure what it is.
Old Feb 8, 2003 | 09:26 AM
bumpin_BII's Avatar
bumpin_BII
the 86 had the crank sensor and the tac wire breaks all the time in these. myne did this to for about 20 mins. turned out a wire had fatigued so check all the sensor wiring to.
Old Feb 10, 2003 | 10:20 AM
wvmac's Avatar
wvmac
Thanks for the help! We finally traced it down to the ERG sensor above fuel rail ( $65). It was grounding out the computer.
Old Feb 10, 2003 | 12:35 PM
fordluver's Avatar
fordluver
Unhappy 86 Bronco II...fuel/start problem
I'm glad you got it fixed . I'm sorry I was of no help. Angel
dewbug111
Dec 15, 2017 06:05 PM
Big Urn
Jun 24, 2011 07:13 PM
spininspur
Electrical Systems/Wiring
Aug 30, 2009 07:30 PM
fordbroncoIIman
Bronco II
Oct 28, 2007 09:53 PM
Little old Bronco
Bronco II
26
Dec 1, 2003 07:03 PM
