1983 ford f150 not running good
Check ALL your vacuum lines for cracks, splits, holes etc. Better yet get enough vacuum hose from the local store with Tee's and other fittings and REPLACE all the vacuum hoses (gawd knows they are heat damaged after 19+ years). Other items you might check are PCV stuck OPEN, CHOKE Stuck Closed (black smoke), dirty plugs (oil fouled), carb loose on manifold (lean running).
Start with the basics. compression tests, Plugs, points (if you have them), timing, carb clean and adjust.
Larry
Larry
What color is the smoke? If it's black it is fuel.
Take the air cleaner off and have someone watch while you crank the truck. There's a good possibility that fuel will be coming out of the vents and going into the engine. This will make it so rich that it will barely run if at all. The cluprit is either a stuck float or excessive fuel pressure.
how can i slow down the fuel pressure going into it it runs with some of the vacuum hoses off but will smoke black smoke real bad i had it backfire today for some odd reason if i plug all the vacuum lines back in it stalls out and will not even try to start would a possible timing be the problem or would a blown gasket be another cause for concern help this is really frustrating to not know whats up with my truck
on
1 Post
![Flaming Bounce](images/smilies2/firejump.gif)
Hi, If your engine is pumping out black smoke you have A WAY OVER RICH
![Hair](images/smilies2/smhair.gif)
![Pacing Floor](images/smilies2/sad2.gif)
Bob /stractor
![Bouncing](images/smilies2/bounce.gif)
gigi
07-10-2001 03:25 PM
