First drain from the petcock on the bottom of the radiator enough a/f to drain the entire de-gas bottle on top. That will lower the level enough that you won't spill much. When you're done pour it back in. You might lose a quart though.
i have the 203 thermostat but have problems installing b/c the stock o ring does not seem to work or seal well. searched numerous auto parts stores for an o ring that is grooved but no luck.
so is this billetr housing the answer i'm looking for? based on the responses it seems i need this, plus some new 9mmm bolts. does it come with a o ring? anything else i need? thanks!
Stephen,
I sent the bolts you wanted, should be there in a few days. Don't worry, it's all on me.
Since I saved you a bunch, why don't you join up for a year or three.
Dave.
