203 Stat
Old Dec 2, 2008 | 06:01 AM
Blankie's Avatar
Blankie
203 Stat
Where is the best place to purchase a 203 Stat. Thanks
Jim
Old Dec 2, 2008 | 07:36 AM
Neal 97 250's Avatar
Neal 97 250
For a '96-'97 you can only get then at dieselsite.com. If it is a '95 or older it is standard and can be bought at the dealer or maybe the parts stores.
Old Dec 2, 2008 | 10:20 AM
wmiller's Avatar
wmiller
what is the difference in the 2? I remember reading something about it before but cant rememebr
Old Dec 2, 2008 | 10:39 AM
Blankie's Avatar
Blankie
Thanks, I have a 96 F350. Getting ready to install 3" DP and air filter. Thought I would do coolant and t-stat at same time.
Thanks again
Jim
Old Dec 2, 2008 | 10:52 AM
Neal 97 250
Blankie (Jim), you may also want to get the thermostat housing neck also. They tend to not seal and will rot thru. The new one also has better a seal.
wmiller, the '95 and older are shorter and will fit in the '96-'97 housing but it is not long enough to seal against the backside for the by-pass and therefore will keep the truck cool at the gauge but the rear of the motor will skyrocket in temps. Therefore cooking your motor from the back forward and you will not even know it. The '96-;97 thermostat is longer and the 203° stat is only made by dieselite. This explanation is to the best of my memory and may only be partially accurate but you get the point. Gettin' old and memory does too. LOL
iverger
Aug 12, 2016 08:10 PM
Talyn
May 9, 2016 10:33 AM
Wieckster
Sep 26, 2008 08:33 PM
alstieg
Oct 30, 2007 06:25 PM
strokin'_tatsch
17
Aug 8, 2007 08:39 AM
