Truck stalls
Old Nov 5, 2007 | 02:35 PM
richardmiller's Avatar
richardmiller
Truck stalls
Any ideas on what is going on. My 2001 powerstroke will be going along and then simple die while coasting. I replaced the fuel filter and replaced both batteries but still have this problem. It does not die often, maybe every ten minutes or so and then does restart.
Thanks, Rick
Old Nov 5, 2007 | 03:24 PM
aklim's Avatar
aklim
CPS maybe? Will it do that in idle? Fuel pressure? I had that happen with a bad fuel pump once.
Old Nov 5, 2007 | 04:03 PM
richardmiller
thanks
It dies at idle. I'll try replacing the CPS and see what happens. The fuel bowl seems full and I can hear the fuel pump charge when I first turn the key. I'll post if it works.
Old Nov 5, 2007 | 04:04 PM
aklim's Avatar
aklim
Try CPS. Too bad you don't have a pressure gauge so you know what it really is.
Old Nov 5, 2007 | 04:06 PM
richardmiller
when your fuel pump went out could you still hear it trying to charge?
Old Nov 5, 2007 | 04:09 PM
aklim's Avatar
aklim
On my 2 cars that had bad pumps, there were 2 pumps to work with. One had an in tank and an external and the other had 2 external ones. They did whine but were low in pressure.
Old Nov 5, 2007 | 05:06 PM
clintbonnie's Avatar
clintbonnie
Welcome to the Forum..
Be sure to get the new designed, grey in color... see:
http://fordparts.com/cart/?pn=F7TZ-1...&submit=Search
Old Nov 5, 2007 | 07:56 PM
F350-6's Avatar
F350-6
Welcome to FTE richardmiller. Just in case the CPS doesn't solve your problem save the old one for a spare (but you will need a new o-ring)
If you still have problems let us know and we'll help you get it fixed. The CPS is a cheap easy place to start.
Old Nov 5, 2007 | 10:33 PM
richardmiller
Thanks for the help. Seems the CPS is doing the trick. Ten minute fix. Part was 30 bucks at the dealer.
