390 Fe
Old Nov 1, 2007 | 07:42 PM
coloradoforder's Avatar
coloradoforder
390 Fe
Need a flywheel for a '66 390. Anyone know the casting numbers so I can at least make sure what I'm looking at in the boneyard.
Also, have a '65 f-250 4x4 with a 352. The motor mounts I don't think are stock - the front is behind the radiator and bolts to the block below the timing cover, the rear bolts to the rear cross-member, anyone familiar with this setup?
Coloradoforder
Old Nov 1, 2007 | 08:31 PM
Customcab's Avatar
Customcab
Can't help ya on the 390 question; I not 100% sure 390 was a 66 option for trucks? I do know your question in regards to your 65 4x4 motor mounts location are right because of it being a 4x4 setup. Check your block number on your 390 (located on passenger side near starter. I wonder if it starts with C6TExxxxx..
I'm not the final answer on your questions but I hope I helped...
Welcome aboard....
Mitch
Old Nov 1, 2007 | 10:28 PM
Mil1ion's Avatar
Mil1ion
It wasn't .
A 352 was.
For a 66 390..you need a Galaxie or Fairlane application.
Old Nov 2, 2007 | 04:09 AM
jowilker's Avatar
jowilker
Coloradoforder, The 66 4X4 was still built on the 60-64 chassis and uses different engine mounts.
The 428 & 410 FE engines use the externally balanced 428 crank with a different flywheel, all others use the same one. Basically any flywheel you get from a truck should work as there were no 410s or 428s installed in trucks.
The flywheel should be available from your favorite parts house too.
John
Old Nov 2, 2007 | 07:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
CAR: 1965/70 352/390 (except 1966/67 Mustang/Fairlane GT)
TRUCK: 1965/72 352/360 F100/350
C5AZ-6375-K .. Flywheel ~ Marked: C5AE-6380-J / (6) 5/16"-18 pressure plate attaching holes on a 12 3/8" bolt circle / Includes 184 tooth ring gear.
>>> Use with 11" clutch <<<
CAR: 1966/67 390 (Use with Fairlane/Mustang GT)
TRUCK: 1968/72 390 F100/350
C5AZ-6375-L .. Flywheel ~ Marked C5AE-6380-K. Specs are the same as above except the bolt circle is 12 7/8"
>>> Use with 11 1/2" clutch <<<
You didn't specify what the 66 390 flywheel is for, but reading your other post, you said for standard 4 speed. There were two different four speeds available: Warner or New Process.
Information Sources: 1965/72 Ford Car and 1964/72 Ford Truck Parts Catalogs.
Old Nov 2, 2007 | 12:08 PM
bertha66's Avatar
bertha66
John
The F250 4x4 used the 60-64 chassis, the 66 F100 4x4 used the 65-66 chassis.
Old Nov 2, 2007 | 04:40 PM
jowilker's Avatar
jowilker
Allen, You just might be right, don't know my 4wds like the 2wds. Sure did think I read here that the 4X4s were on the older chassis though.
John
Old Nov 2, 2007 | 08:42 PM
NumberDummy
John
Allen is correct, the 1966 F100 was built on the new chassis, but it was introduced after the rest of the 1966 lineup came onto the market. The first 1966 F100 4WD was serial number 778,001.
Old Nov 2, 2007 | 11:21 PM
coloradoforder
Thank you all for the help. I think what I'm looking at is a flywheel, 184 teeth, clutch disc of 11-1/4 and total overall diameter of 15-5/16. Found no casting numbers of any kind - going to run me 80 bucks including resurfacing grind, any opinions?
Old Nov 3, 2007 | 01:54 AM
NumberDummy
Ford, in their infinite wisdom, marked some flywheel casting/engineering numbers using a rubber stamp!
If there's heat (blue) spots on that flywheel, don't bother resurfacing it.
fourboltmain3401
Apr 20, 2016 08:20 PM
NS70250
Apr 12, 2016 09:36 AM
4x4man514
Apr 15, 2012 04:30 PM
amosmoses
Mar 3, 2012 11:59 AM
utvol1984
Jan 10, 2003 11:31 AM
