Not running smooth
Old Oct 31, 2007 | 07:46 PM
Whisperinghorse's Avatar
Whisperinghorse
Thumbs down Not running smooth
From Idle to about 1500 rpms it feels like it is hesitating, after 1500 rpms it smooths out and runs great ?
Old Oct 31, 2007 | 07:51 PM
1997F-350's Avatar
1997F-350
injectors??????????
Old Oct 31, 2007 | 07:59 PM
bkcowboss's Avatar
bkcowboss
Whisper, I had the same problem, read the literature for hot shot secrets, I used it and it works great
http://65.247.66.223/closeup.asp?cid=9&pid=102&offset=0
Chris Gale is a sponsor and he is on here quite a bit, he may see this thread
Old Nov 1, 2007 | 08:39 AM
Whisperinghorse
1997F the more I think about this the more I think you could be right!!!
Old Nov 1, 2007 | 08:41 AM
Whisperinghorse
bkcowboss I'll read up on this and hopefully the other gentleman will see this thread. Thank you.
amjperformance's Avatar
amjperformance
Sounds like injector to me too.
Old Nov 1, 2007 | 07:28 PM
Whisperinghorse
Well I've got my work cut out for me, so I guess I might as well do them all as I have 212,00 miles on them.. Time for new injectors YES
Old Nov 1, 2007 | 08:27 PM
bkcowboss's Avatar
bkcowboss
mine was injectors also, that is what made me research the HSS, I had two noncontributing injectors, I have put 15,000 miles on since then with no issues, that is the big thing is coking of oil on the injector can cause the problems, although.....could be time to get stage 1's
Old Nov 1, 2007 | 08:29 PM
c00nhunterjoe's Avatar
c00nhunterjoe
make sure an injector wire isnt burnt under the valve covers, but its a long shot on that one i think
Old Nov 2, 2007 | 07:31 AM
mcdavidson's Avatar
mcdavidson
Just a thought,
Couldn't this also be caused by a fuel / air leak in the lines say near the fuel pump and or bowl? Air in the lines combined with a loss of fuel at low volume?
Have you checked the valley for a leak?
Old Nov 2, 2007 | 12:32 PM
Whisperinghorse
Hey cOOn I did replace the wires under valve covers and I did have a burnt one, IPR seals and connector wires and there is no fuel in the valley. Besides the intake and exhaust mods I have nothing modified untill I get this probleme solved. Is it hard to rebuild the injectors?
OldBlack4x4
Oct 9, 2014 12:42 AM
samiott
Aug 2, 2013 07:00 AM
86ford185
May 15, 2012 09:49 PM
dencrawford
Bronco II
Dec 22, 2011 05:31 PM
msmith53
19
Aug 3, 2009 07:03 AM
