Sponsored by: Real Truck
Speedometer Issue
Old Oct 30, 2007 | 06:43 PM
dludlow's Avatar
dludlow
Speedometer Issue
Have run into an issue - well, it's a small one, non-the-less an issue.
2006 F-250 v10 4x4.....
Over the last 2 weeks + the speedometer has stopped working and stays at 0mph. This has seemed to happen on cold nights where the temp. has gotten into the 40's, high 30's here in Maryland.
Does anyone have an idea in regards to what might be going on? How to fix it? etc... I do have 35'' bfg's on it - doesn't seem like that should cause an issue other then the speedo being off 5mph.
Thanks everyone!
Old Oct 30, 2007 | 06:46 PM
redford's Avatar
redford
FTE Leadership Emeritus
I'd start by looking at your Vehicle Speed Sensor (VSS). It's a sensor on the top of your rear differential, It may just need cleaning or it may need to be replaced, but it's easy to remove and not expensive.
Old Oct 30, 2007 | 06:51 PM
Brian0445's Avatar
Brian0445
My 99 does the same thing, i checked the vss on top of the rear end, but everything tests fine.... It happens to my truck, most of the time on the first start up, usually i stop shut the truck off and then re-start and it works fine. Still leads me to think that there is an electrical problem somewere. But it doesnt happen frequently enough to bother me yet...
Old Oct 30, 2007 | 07:11 PM
dludlow's Avatar
dludlow
Thumbs up
exactly what is happening with me... happens here and there, not all the time and like I said - it seems to be colder evenings. If I shut the engine off, fire it back up the speedo works. Starting to wonder if I ever can trust it
Thanks guys!
Old Oct 30, 2007 | 07:54 PM
UGA33's Avatar
UGA33
I had the same issue. Dealer ended up replacing the entire instrument panel and all is well again
Old Oct 30, 2007 | 08:17 PM
dludlow's Avatar
dludlow
Was it just your speedometer or your odometer, tach, everything?
Thanks UGA
Old Oct 30, 2007 | 08:32 PM
UGA33's Avatar
UGA33
just my speedometer. It would stay at 0 a lot and i would just use the tach to tell how fast i was going till i had time to take it in. THe first attempt thay tried to do some electrical stuff to it then finally just replaced the entire instrument cluster and has been acting right for 15k miles
Old Oct 31, 2007 | 06:43 AM
seville009's Avatar
seville009
There is a TSB on it; do a search on it.
Had the same problem in Feb 2007 with my 2006 F350 CC that I bought brand new in Dec 2006. The speedo would be either zero or show me going say 90 mph when I was only doing maybe 30. Would do this for awhile, then stop, then do it again, etc.
By the time I was able to bring it to the dealer, it wasn't doing it, so naturally the dealer wouldn't.couldn't do anything.
I figure that when the winter cold sets in and it does it again, I'll drive it right to the dealer.
timbo126
Maryland Chapter
Dec 24, 2014 10:01 AM
Cheezpo
Dec 8, 2014 07:52 PM
fastcarsspeed
Maryland Chapter
21
Jan 10, 2011 06:38 AM
BPofMD
Maryland Chapter
548
Feb 28, 2009 10:31 PM
tuffguy
Dec 3, 2002 04:11 PM
