Crazy Speedometer
Old Dec 3, 2002 | 11:34 AM
tuffguy's Avatar
tuffguy
Crazy Speedometer
Gents,
I have a 78 F-150 4X4 and lately, the speedometer has been wiiging out when I get past 50MPH. It seems as though the needle gets lazy and can't stay in position. Any thoughts?
Old Dec 3, 2002 | 11:57 AM
swall's Avatar
swall
Post Crazy Speedometer
an easy place to start is on the xmsn were the spead cable hooks up and see if it is secure, if it is, pull the gear out and check the gear. They get worn and start slipping.
Second, look on the back of the instrument cluster, may be comming loose. check for any binding, good luck.
77 F100
Old Dec 3, 2002 | 12:54 PM
laptopgeek's Avatar
laptopgeek
Crazy Speedometer
Tuffguy --- the cable might be wimping out on you (binding), as they do get dry. Speedo cable lubricant is available at your friendly Napa automotive parts store - remove the connector behind the speedometer and gently slide the cable out and lube it and slide it back in and try that....
Good luck...
Old Dec 3, 2002 | 02:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
Crazy Speedometer
The cables sometimes wear out and have to be replaced.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 3, 2002 | 04:11 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Crazy Speedometer
jimd1050
6.4L Power Stroke Diesel
Dec 20, 2011 01:55 PM
purecty
Sep 17, 2011 05:09 AM
1972RedNeck
Aug 10, 2011 03:08 AM
mjshagnasty
17
Mar 25, 2011 06:50 PM
hemiyota
May 6, 2006 06:56 AM
