help with brakes
Old Nov 5, 2007 | 07:36 PM
pgw85706's Avatar
pgw85706
big 390.....I would suspect one of the vehicle speed sensors has gone bad. On the 4x4 there should be 3....1 on each front wheel and one on the rear differential. OBD II code reader typically will not pull the ABS codes, it takes a special reader. Need proper diagnostics to check which sensor is suspect....the front sensors are about $170 each and the one on the rear differential is about $15.
Old Nov 6, 2007 | 06:41 PM
Peter94's Avatar
Peter94
Revolution:
Try adjusting your drums. I've been told that too much moisture in an underadjusted drum will cause the shoe to suddenly grab and lock the brake up.
bubba_3711
Apr 22, 2017 10:38 PM
KDCS
Jul 10, 2013 11:16 AM
pistolhunter
Feb 22, 2011 07:02 AM
rangersvt04
Dec 5, 2006 11:22 AM
pissed off in mn
Dec 13, 2003 08:32 PM
