ABS light always on
Old Jan 23, 2012 | 08:48 PM
bubba_3711's Avatar
bubba_3711
ABS light always on
i replaced the speed sensor in the rear end, i was garenteed that was the peoblem. they were wrong the abs light is still on all the time. when i replaced the sensor the light stayed off till i steped on the breaks again.
Old Jan 23, 2012 | 09:53 PM
oldbird1965's Avatar
oldbird1965
There are no grantees! Check your fluid, I'm sure you did that. Check your codes.
Old Jan 23, 2012 | 10:15 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Try getting a code reader and clear the codes, if its still there it may think the problem is still there.
Old Jan 23, 2012 | 10:45 PM
bubba_3711's Avatar
bubba_3711
fluid is fine, and i didnt have batterys in the pickup for at least 2 weeks, wouldnt that have reset it? and somthing is wrong when i hook up a code reader it wont cominucate with it. in either the OBD2 port or the old OBD1 port under the hood. and i was readin somthin about there being a ABS sensor on each wheel?
Old Jan 23, 2012 | 11:17 PM
Ford4Life7.3
A lot of readers will not read our PSD's. You have to find one that will.
Old Jan 24, 2012 | 07:07 PM
ckal704's Avatar
ckal704
Not saying that this is the answer, but check that the connector hasn't come loose. It is in the vicinity of the master cylinder. I was under the hood and knocked mine off once and the light would come on after I touched the brakes.
Old Jan 25, 2012 | 03:05 PM
madd91's Avatar
madd91
My ABS light would not go off either after I replaced my rear ABS sensor. After researching around, we found out it was the RABS Valve. It is located on the frame rail on the drivers side near the front wheel. You can pick one up at NAPA for around $150 (if I remember correctly). I replaced it, and have not had any other problems.
Old Apr 22, 2017 | 10:38 PM
Salvador Garza's Avatar
Salvador Garza
Need help! Rabs seized nut
Is that just one long nut or is it a adapter , and it wont budge . I cant back it out im afraid ill crack something
please I need suggestions on how to get it out.
Garrthomp823
Sep 8, 2014 07:58 PM
kutsyy
1997 - 2003 F150
Sep 16, 2011 12:36 AM
spinella
Jun 22, 2011 01:24 PM
<TDUB>
Modular V10 (6.8l)
Dec 25, 2008 10:44 AM
the4by4freek
1997 - 2003 F150
Jan 25, 2004 04:43 PM
