Cat problems.
Old Oct 27, 2007 | 12:16 AM
joker944's Avatar
joker944
Question Cat problems.
I think my cat is stoped up on my 96 exlorer 4.0. It has two cats on it and I realy don't know witch on it is. I don't have the money to replace it so I am thinking about pulling it off and gutting the inside for now. Does anyone know what effects that will have as far as power or fuel ec.?
Old Oct 27, 2007 | 10:21 AM
dkf's Avatar
dkf
More power and better mpg compared to the clogged cat.
Old Oct 27, 2007 | 10:28 AM
kens64's Avatar
kens64
Remove the 02 sensor foward of each cat one at a time. If the engine runs better that is the clogged one. Normally a clogged cat will kill tons of power and is definately noticeable.
Weld a pipe inside the gutted cat the size of the rest of the erxhaust system so the exhaust gasses still flow well.
Old Oct 27, 2007 | 05:47 PM
joker944's Avatar
joker944
Cool never thought of doing that. Makes complete sense. But for future reference (when I have the money) would it be better to replace with a universal or high flow cat than having it gutted? Also will gutting it out cause my check engine light come on. I just spent a lot of time and money to fix every thing to get it cleared. Thanks.
Old Oct 27, 2007 | 06:28 PM
dkf's Avatar
dkf
Gutting a cat is against the law in any state, however like most of the laws on the books its not enforced or checked for.
If the 4.0l has o2 sensors after the the cats the light may come on.
A univ. cat usually gos for around $80-$100 each. If your state isn't a sniffer state you won't have to worry about it passing inspection with a gutted cat.
Old Oct 27, 2007 | 08:33 PM
kens64's Avatar
kens64
IMO, spend the money on an aftermarket cat. They are not all that expensive and you will have nothing to hide should the emission system come into queation for any reason.
Wehter the laws are enforced or not, the laws still exist and you can get caught.
Old Oct 27, 2007 | 10:58 PM
Bear River's Avatar
Bear River
Former ******
Your '96 explorer is OBD-II compliant, so your light will come on if you gut the cat. What most often happens here is that the packing around the converter (usually the front one) fails to hold the brick firmly and the brick begins to move within the case. Over time, from the expansion and contraction of the case the brick with move until it either rounds off and turns sideways or it cracks. Once this happens, its all over and the converter clogs itself. The second most common is that the fuel eto air ratio becomes too rich and the catalyst overheats and either melts down or cracks. If the first happens, you just replace it. If the second happens you have to fix the problem that caused the failure, and then replace the converter.
On an OBD-II vehicle ('96 and newer) there is no way to eliminate the converter and still keep the CEL off. And before someone here suggests MIL eliminators, those are no longer available within the US, and the companies that made them have been closed down (at least the companies that were located in the US).
Old Oct 27, 2007 | 11:51 PM
joker944's Avatar
joker944
Yeah I know it's wrong to gut it and I should replace it, but I got layed off at my job and replace by some --- that would do it for half the price so I am just looking for a temp. fix until I get back on my feet. Trust me I don't like to rig my ride my 96 will usually out perform a lot of new explorers and everything works on it. I am kinda **** when it comes to my car, you know the don't lean on my car kinda guy.
Anyway, how do you tell if it overheated or melted? I just recently had to clean the entire egr system and replace the pressure fed back sensor and the mass air flow sensor, would that have any thing to do with the cat clogging. Also b/f I fixed the maf and the egr system I was getting a code for the O2 sensor in bank 1 but that went away when I fixed the egr and maf. And when I bought it a while back the guy I got it from had 140,000 on the orig. plugs and wire and the contacts on the plugs were completely gone.
Old Oct 28, 2007 | 12:05 AM
kens64's Avatar
kens64
In your case if there is a CEL I would check that first, it may be a sensor and not a cat. Like I said if one is clogged there is usually a pretty serious power loss. That doesnt sound like your problem.
Good luck with the job situation, I have been there before myself.
Old Oct 28, 2007 | 12:46 PM
Bear River's Avatar
Bear River
Former ******
If the converter has melted, it means you have a bad fuel managment problem and a leaking injector or bad O2 sensor is probably to blame. If you have a clogged cat, severe power loss is often the result. A lot of people quickly jump to blaming the converter for every problem on the vehicle, but since I deal with converters every single day, I can tell you from experience that converter do not fail without a cause unless the vehicle has defect in the design. The explorer does not have a history of problems, at least not more so that any other model.
Old Oct 29, 2007 | 12:22 AM
godblessmud's Avatar
godblessmud
Better play it safe and scrap both cats, that'l clear ya right up! Just make sure you aint got emmisions inspection
Old Oct 29, 2007 | 12:33 AM
Bear River's Avatar
Bear River
Former ******
I don't think you understand, its a 1996 and that makes it OBD-II. It monitors its own emissions and triggers a light if the converters are not working. Even in a non-emissions area, you will fail for a CEL. I understand you are in a tough financial situation right now. My advise is to look at other possibilities, a clogged cat is not the most likely suspect, nor the cheapest. And even if it is clogged, something probably caused it to melt or crack, and unless that something is fixed, it will do it again. I recommend further diagnostics to figure out what is going on. You can try removing one of the front O2 sensors and see if that doesn't improve the way it runs. If it does, then a clogged cat is a very real possibility.
Take care and hold in there Joker944. I just don't want you to spend your time and money throwing parts at a problem. Make sure that the converter is bad before you try to replace it. If you are having performance problems look at everything that can cause your symptoms in order of simplicity and price.
ramrod7373
May 4, 2010 04:05 PM
TigerDan
76
Jul 18, 2005 05:13 AM
firebug
24
Feb 24, 2005 04:52 AM
turbo69
1978 - 1996 Big Bronco
Jan 25, 2005 01:31 AM
jwlines
Modular V10 (6.8l)
May 26, 2003 04:35 PM
