Another computer build thread...sorry
Old Oct 26, 2007 | 05:28 PM
herman391's Avatar
herman391
I'm sorry to start another one of these threads but I'm looking into building a new computer for my sister and I haven't been paying much attention to the new advances in hardware technology lately so I'm a little behind on the times. I took computer engineering and computer science all through highschool so I'm not worried about acutally putting together the thing(plus I'm sure everybody here will be able with problems I run into), just worried about having good parts and them all being compatible. She will be using the computer mostly for internet, viewing pictures and listening to music as well as word processing and things like that.
Here's what I've come up with
Motherboard/CPU/RAM combo-$307.99
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3163514&Sku=MCM-M2NE-5400A
Case-$60.99
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2541414&CatId=1843
Hard Drive-$79.99
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3318110&CatId=2458
DVD Burner-$48.99
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3127312&CatId=482
Extra RAM-$24.97
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1071038&CatId=1649
Video Card-$77.99 ***This is where I'm confused, I know it's probably overkill but it's compatible with two different types of moniter interfaces, and I don't know which monitor she will pick.***
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3244228&CatId=1560
Heatsink Fan-$15.99
http://www.tigerdirect.ca/applications/searchtools/item-details.asp?EdpNo=2604150&body=REVIEWS#tabs
Last but not least, she wants Vista will this be compatible with it? If not what changes should I make? Any advice is great thanks!!!
Old Oct 26, 2007 | 05:32 PM
Mil1ion's Avatar
Mil1ion
Looks Okay to me as it is something I would build.
One thing I would make sure of is front and rear cooling fans,.
Just the one 1200 mm fan comes with the case ?
Old Oct 26, 2007 | 05:37 PM
herman391's Avatar
herman391
Mil1ion, According to the description on the site (way at the bottom of the page) it has two 120mm fans, one front and one back, but I can always add more fans if it's running hot after I'm done. She live's about 10 minutes from the Tigerdirect store in Missisaugua so it'll be a quick trip to make if I need to.
On Edit: I looked again and I don't think it comes with the second fan. Do you think heat will a problem with this setup?
Old Oct 26, 2007 | 06:02 PM
Mil1ion's Avatar
Mil1ion
I bought a 2nd fan for my "Swing" case just for the heck of it.
Princess auto sells computer fans in their surplus section.
Old Oct 26, 2007 | 10:46 PM
Netfly's Avatar
Netfly
Looks good. I like Asus motherboards and the AMD is a goood value. Only suggestion I would make is get the Seagate HD.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3206259&CatId=139
For $30 extra you get more than double the space and a 5 year warranty.
Old Oct 27, 2007 | 08:34 AM
lswartz's Avatar
lswartz
Has she considered a laptop? Even the cheapest one will do everything you mentioned that she uses a computer for. Plus, Black Friday will soon be here if you can fight your way through the shopping frenzy. Some allow shopping online but you must check their rules & web sight very early in the morning.
*2fords*
Jul 26, 2013 07:37 AM
ford2go
18
Aug 1, 2007 05:00 AM
Cruiseomatic
38
Sep 19, 2006 09:14 PM
I6power
Jun 20, 2006 07:51 AM
Fordlover55
Oct 26, 2004 09:17 AM
